#21
![]() ![]() ---------- Post added at 10:49 AM ---------- Previous post was at 10:48 AM ---------- Quote:
---------- Post added at 10:50 AM ---------- Previous post was at 10:49 AM ---------- [quote=dogger315;726225]Let the fun begin! Looks like you have a real nice basis for your resto - nice find. ---------- Post added at 10:53 AM ---------- Previous post was at 10:50 AM ---------- ![]() Down to the frame ---------- Post added at 10:55 AM ---------- Previous post was at 10:53 AM ---------- ![]() Motor was filthy, no surprise. ---------- Post added at 10:57 AM ---------- Previous post was at 10:55 AM ---------- ![]() Swingarm in pretty good shape but really dirty/ grimey. |
#22
![]() Took about a week but got the tank and airbox clean. ![]() ---------- Post added at 05:30 PM ---------- Previous post was at 05:29 PM ---------- ![]() ---------- Post added at 05:31 PM ---------- Previous post was at 05:30 PM ---------- Swing arm soda and then media blasted. PC clear next ![]() ---------- Post added at 05:32 PM ---------- Previous post was at 05:31 PM ---------- ![]() ---------- Post added at 05:33 PM ---------- Previous post was at 05:32 PM ---------- Motor pulled. ![]() ---------- Post added at 05:35 PM ---------- Previous post was at 05:33 PM ---------- Soda blasted motor so I had something clean to work with prior to tear down. New Wiesco top end and OEM bottom end going in. ---------- Post added at 05:36 PM ---------- Previous post was at 05:35 PM ---------- ![]() ---------- Post added at 06:03 PM ---------- Previous post was at 05:36 PM ---------- Brakes turned out really good and this was just a soda blast. Rebiulding them completely. ![]() ---------- Post added at 06:04 PM ---------- Previous post was at 06:03 PM ---------- ![]() ---------- Post added at 06:05 PM ---------- Previous post was at 06:04 PM ---------- ![]() ---------- Post added at 06:28 PM ---------- Previous post was at 06:05 PM ---------- Soda blasted carb, rebuilding it. ![]() ---------- Post added at 06:58 PM ---------- Previous post was at 06:28 PM ---------- All new bearings going in. Plus didnt want a used PC silencer, selling that. ![]() ---------- Post added at 07:09 PM ---------- Previous post was at 06:58 PM ---------- of course this! ![]() ---------- Post added at 07:11 PM ---------- Previous post was at 07:09 PM ---------- Here is the 2004 I did. Found it brand new still in the crate in 2011! Tom Morgan did the motor... ![]() ---------- Post added at 07:12 PM ---------- Previous post was at 07:11 PM ---------- ![]() ---------- Post added at 07:19 PM ---------- Previous post was at 07:12 PM ---------- Heres the Pro Circuit works pipe it came with. It was completely rusted. I'm selling this as I'm going new with almost everything. ![]() ---------- Post added at 07:24 PM ---------- Previous post was at 07:19 PM ---------- This is on its way from Europe... ![]() ---------- Post added at 08:28 PM ---------- Previous post was at 07:24 PM ---------- More parts came today... ![]() |
#23
![]() Not sure why the pic didnt come through... ![]() |
#24
![]() Took a break from the CR project to finish my 450. All done now so the focus can be on the CR now. ![]() |
#25
![]() Few more parts arrived yesterday. More Honda parts due to arrive week of January 4th. ![]() |
#26
![]() ![]() ---------- Post added at 09:37 PM ---------- Previous post was at 08:46 PM ---------- another pic of the motor after soda blasting. ![]() |
#27
![]() Anyone have experience with DEP pipes? Their steel works pipe looks really good. |
#28
![]() That tank and airbox DID clean up nicely. One word of caution about blasting an engine before disassembly. Once you have done that, you are pretty much committed to a tear down to bare cases. It's nearly impossible to keep the media out of the internals due to all the vent and weep holes located around the engine. I know you mentioned a new OE bottom end, so I'm assuming you are already going to replace all the bearings, seals, circlips, springs, etc., etc. Keep in mind the Right side case cover, water pump and clutch cover came painted from Honda, everything else was either plastic or bare cast. Here's a picture of what I'm talking about: ![]() I took this when I was doing color matching for powder coat. The clutch cover on the Left is a new OE Honda painted one and the stuff on the Right is the powder coated match. I really like the results I've seen from vapor blasting, the cylinder and head look new. Be careful blasting carburetors, they are clear anodized and any thing stronger than walnut shells will remove the anodization exposing the carb body to corrosion. Here's a picture of a PJ I bought off of EBay a while back: ![]() It was OE on a 93 that somebody was parting out and I needed one for my 93 showroom restoration. I took it apart and cleaned it in a hot solvent tank, then cleaned it in an ultrasonic parts washer with an Aluminum specific cleaning solution. Then I put a rebuild kit on it, replaced the throttle valve, cap, choke, vent lines and hardware. If you look closely, you'll see a slight shine to the surface of the carb body. That's the anodization still in tact. As you can tell, there is a lot of work involved in bringing a lowly PJ back to life and it's only worth it if you are doing an OE resto. For anything else, i would swap in a new PWK. That PC Works pipe is worth quite a bit of money if you restore it back to it's original condition. They have been NLA from PC for a while now and all the guys doing McGrath replicas want them. |
#29
![]() Quote: |
#30
![]() To restore the original finish from what you have now depends on if there are any dents that need to be eliminated. If there are only a couple of small dents you can remove them with a stud puller. You can also send the pipe to Pacific Crest and have them heat and blow out the dents. Just make sure you tell them to leave the pipe bare after the work so that they don't put on a coat of high temp Black paint as they usually do. Once the pipe is dent free it's time to restore the oiled bare metal finish. You will need a couple of Green Scotchbrite pads and a can of WD40. Work on a small section at a time. Spray down the section and hit it with the pad working along the long axis of the pipe. The finish you're looking for is similar to the inlet pipe on your PC silencer. Once you have the finish back, use a torch along the welds to bring back the bluing if the media blasting removed it. You can also do the WD40/Scotchbrite tecnique to restore the extruded portion of your swingarm before clearing it. Since you aren't doing an OE resto, I would recommend keeping and using the PC pipe and silencer. These pipes were developed and tested with the help of Team Honda at the time, so there really isn't anything better. |
Thread Tools | |
1993 Honda CR250 Build Finally Finished | dogger315 | Dirt Bike Restorations and Builds | 228 | 12-09-2016 07:15 AM |
1993 CR250 Build Update | dogger315 | Dirt Bike Restorations and Builds | 44 | 08-04-2015 08:50 AM |
1993 CR250 Frame up restore - questions for the experts | Hawaii Rider | Dirt Bike Restorations and Builds | 7 | 09-26-2014 07:41 AM |
1993 CR250 Frame up Restore - Here we go... | Hawaii Rider | Dirt Bike Restorations and Builds | 11 | 07-19-2014 01:09 AM |
1993 CR250 build | dogger315 | Dirt Bike Restorations and Builds | 11 | 10-25-2009 11:06 AM |
