Old 07-06-2018, 12:07 PM
Last Online: 06-25-2020 07:29 PM
The build is moving along. I ordered a suzuki oem top steering stem bearing so that is sorted.
---------- Post added at 11:07 AM ---------- Previous post was at 10:38 AM ----------
I saw this listed on another forum without much detail so I though I would see if it would work because the stock 84 footpegs are very narrow. So, I pulled my frame out of my shipping box so I could drill out the peg mount holes before having the frame powder coated.
These are the stock pegs.
These are the 98 RM 250 pegs with pins and springs.
The pins are bigger on the 98 so you have to drill out the holes on the frame to 9.5mm which is a 3/8 inch drill bit. I used carbide bit and a Milwaukee hammer drill at super slow speed. You have to maintain pressure on the drill but barely rotate the bit, as long as you are getting long chunks of metal you are doing fine but if you are just getting metal dust, you are going too fast and you will ruin the bit.
It took me about 6 minutes per each peg mount. Afterwards, the pins fit perfectly.
Pegs bolted right up but I did have to file the brake side a little to clear a frame weld.
84 RM 250 peg and 98 RM 250 peg
Old 07-21-2018, 07:45 PM
Big stuff is still at the powdercoaters. I just cleaned up some stuff to have it cad plated.
Here is the stuff after cleanup waiting to be cad plated.
It took a while to get off all the rust
I had to use a mini sledge to get the rear axle out. I thought it was impossible to clean up the threads. I bought a Snap On Thread Chaser RD7-18 which is a M16-1.50 thread pitch. It worked!
---------- Post added at 06:36 PM ---------- Previous post was at 06:34 PM ----------
The new seat cover just arrived.
---------- Post added at 06:45 PM ---------- Previous post was at 06:36 PM ----------
Btw, I bought a small drill press and mounted it on the workbench last night.
It has a laser....
Old 07-23-2018, 02:44 PM
Trying to resolve a few things while I am waiting on parts to arrive.
I cleaned up the clutch and it doesn't look too bad now. It definitely needs new fibers because of spots of rust, even though the fibers, steels and springs were all well within spec, almost at the spec for new items.
Here is the outer basket.
Reverse side of the outer basket.
Old 07-29-2018, 11:40 AM
Default Pro Grip Rally Grips and Other Stuff
Still waiting on powdercoater and new parts, so I tried to finish up a few other things.
Cut the old scott gripe off the throttle.
I disassembled the throttle and cleaned up the inside of the throttle tube with a dremel and a wire wheel.
I ran a tap through the pro tapers so I can can mount hand guards.
This is the throttle after cleanup with new Pro Grip Rally Grips mounted,glued and safety wired.
MSR Raptor Clutch lever.
---------- Post added at 10:40 AM ---------- Previous post was at 10:31 AM ----------
Finished throttle with new grip glued and safety wired with new assembly bolts.
Bars are ready to mount up.
Old 07-31-2018, 10:30 PM
Default Mastercross Parts/Motos Italy-Watercooled RM 500
Just got these Oem nos radiator louvers yesterday. I have been looking for these everywhere. I found these in Italy of all places. His name is Tiziana and speaks ok English. I had my parts in 14 days. He has vintage works parts, he builds aluminum tanks and he has a bunch of bikes for sale.
Suzuki NOS Louvers
Like this water cooled 1985 RM 500
Click the flag at the bottom and his page will load in English.
http://www.mastercross.net/index_eng.html
Old 08-03-2018, 12:29 PM
Default EBC Grooved Brake Shoes have Arrived
I just contacted my powdercoater, he is a great guy and he is covered up with work so it will be two more weeks before he has my frame, engine, triples, hubs etc finished. I don't mind waiting because he does it the right way the first time.
I did receive some stuff that the average young rider has never seen.
RM 250 EBC Grooved brake shoes!
The grooves are supposed to channel any water or debris out of the shoes.
Old 08-03-2018, 04:20 PM
Default More Stuff
A few more items just arrived.:r ockout
New front brake perch with shorty lever. I am gonna replace those phillips screws with allen bolts.
This is actually a Oem NOS KX stop switch, but it mounts right up with the RM harness.
Motion Pro front brake cable.
Motion Pro throttle cable.
Old 08-16-2018, 04:39 PM
Default First Pictures From the Powdercoater!
Frame.
Brake Pedal and Footpegs.
Old 08-22-2018, 01:57 PM
Default Powder Coated Parts Should Arrive this Weekend
Here are some more photos from the powdercoater.
Barrel, engine case and clutch cover.
Suspension Parts Triples and silencer
Head, magnesium ignition cover and water pump cover.
Rear hub and magnesium backing plate.
Swingarm and suspension links
Old 08-28-2018, 02:03 PM
Default Reassembly Begins!
The powdercoated parts just arrived last night. So, assembly will begin this week.
Here is the frame.
Rear brake lever.
Cylinder and head.
Head again.
Rear brake drum and backing plate.
Wheels and engine cases.
Triples and rear suspension components.
Radiator guards.
---------- Post added at 01:03 PM ---------- Previous post was at 12:53 PM ----------
Front hub and backing plate.
Foot pegs, stock and upgraded.
Swingarm
Another shot of the brake pedal with the folding tip.
Silencer soon to be modified into a spark arrestor.
Triples again with rear brake arm and rad guards.
Cylinder head with water pump and outlet.
Similar Threads for: 1984 RM 250 Full Restoration
CR500 Steelie update turned full restoration MtBiker14 Dirt Bike Restorations and Builds 41 03-16-2018 04:24 PM
94 CR 250 Full Restoration Moto7man 2-Stroke Dirt Bikes - Honda 143 03-04-2018 03:03 PM
1984 Honda XR 250-new project-full restoration! stevo450 Dirt Bike Restorations and Builds 366 11-13-2016 07:52 PM
85 cr 250 restoration oglejust 2-Stroke Dirt Bikes - Honda 16 08-27-2008 11:57 AM
77' DT 100 restoration lgyee4 Vintage Riding 25 04-22-2004 06:30 PM
