Old 07-25-2013, 08:53 AM
stevo450's Avatar
Last Online: 03-13-2021 03:25 AM
Well another stint in the garage.... Hard to get motivated when the money tree hasn't flower just yet lol
Anyways I figured I'd make a start on the brakes....
Hmmmmmmm
hmmmm
Rust.....much???
Looks pretty bad!!! I'm yet to pop out the pistons and check inside.... I'll clean it up and may even be on the hunt for a media blasting setup....that or find some chemical stripper to get through the muck!! If all else fails I've already lined up a fleabay special
Despite all the neglect, a bit of careful heating and clever wrench rendered calipers-0 Steve-1
Managed to remover everything without stripping or breaking anything! Hopefully this will be salvageable once I get it inspected
Sigh, only small updates but hey something to keep the ball rolling...
Old 07-25-2013, 09:36 AM
i think you can use the castings again.
Old 07-25-2013, 09:56 AM
Last Online: 04-16-2021 10:30 AM
Originally Posted by xrbikes View Post
With a bit of elbow grease and patience you can do wonders!
This headlight cowl I bought second hand from the USA and cleand it up, did a rather good job even though I say so myself.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Wet sand and clear coat?
I've restored a couple of Stihl chainsaws and done that with the faded orange plastics. It makes them shine just like new pieces.
Old 07-26-2013, 03:31 PM
Last Online: 10-21-2016 02:47 PM
Heat gun and wet sand, no paint of any kind.
Old 07-26-2013, 03:48 PM
Well done! I wasn't sure if heat would work on that color plastic or not. I've used it with success on the late model Yamaha blue though.
Old 07-26-2013, 04:36 PM
stevo450's Avatar
Default S-C-O-R-E !!!!! Gas tank!
Well one rather important part was sorced for $45.....
Do you guys think I could restore this to the condition of that front cowling?
Remember that the PO decided painting ( yes painting ) a gas tank was a great idea!!! So this one should clean up good and I'll sell the 'white' gas tank.
Some new 'XR250' stickers, a bit of elbow grease, clean up the petcock and it should look good
Old 07-26-2013, 05:14 PM
Last Online: 08-18-2014 04:50 PM
how did you do that if I may ask?..it looks painted
Old 07-27-2013, 05:24 AM
stevo450's Avatar
Wellllllll...........
Back to the workshop!!!!!!
Against my original plan to wait til I had finished the motor before starting on the frame, I started on the frame. Seeing that it would be a while I decided to do things that wouldn't cost money sooooo a bit of elbow grease and got the frame stripped to nothing ready for blasting, prep and PC ( although I'll be waiting on some colour matched powder ) I also got a chance to check over the frame for stopped threads, bent tabs, missing tabs, checking the frame was straight an so on....was happy that I had a good starting point for a frame thankfully there wasn't much to remove.....
Don't be fooled by the pictures... The PO had a dodgy PC job done.....yes that dangit PC got places it shouldn't have....ie threads....looks like I'll be hitting the frame with a tap and die set....
I also went for a drive to a recomended company that specialises in electroplating services.............
WHY?
Well here is the box of bits that will be getting acid dip and zinc passivised or gold passivised, my intention was originally all new bolts......yea.....until the swing arm bolt costs $$$$$.......$$$$$$
I had completely forgotten about being able to do this...... So this is the starting box....
I'm yet to add all the carburator components that need this treatment as well.
This next lot is a combination of parts to be re-anodised or parts going for plasma hard ceramic coating ( high temp for the header and mid pipe ). There are still a few items to be disassembled like the rear shock, front fork outer tubes etc etc
I also tackled the front wheel...I was hoping to reuse the spokes....well boy OHHHH boy I was wrong...they were not reusable at all....so out came the grinder and ....
I'm going to hunt for new spokes as OEM are pricy but at least available. The rims are in ok condition...a few spots need corrosion treatment a one small dent hopefully pushed back....
They are then going for anodising ( clear anodise- once I've smoothed and wet polished the surfaces )
Still a lot of part hunting going on....
Also did another huge chuck out of bits I don't need / will replace....
Here is a little trick:
You know those threaded insert in plastic molds...yea the ones that start turning inside the plastic when you go to undo the bolt.... Well this is an option at times:
You can see I used lock jaw pilliers to pinch the plastic around the insert...this enabled me to loosen the bolts
Old 07-27-2013, 07:50 AM
wFo250's Avatar
will fall over
Last Online: 01-05-2021 07:32 PM
Stevo after you get finished with this bike it is going to be amazing I'm sure, but what is really amazing is the fact that you even found it! ..seeing as it was being stored at the bottom of the sea!
Originally Posted by stevo450 View Post
Old 07-27-2013, 08:15 AM
stevo450's Avatar
Haha I hope that is not a way of saying this is a complete time waste.....
Don't worry I live right on the beach.....just about any project I pick up would have some corrosion! I have a hard enough time with just looking after my RMZ...
Anyways the photo you quoted looks worse than is .... Quite amazing every nut and bolt came off easy, the body is a bit tattered so after MIC I'll decide to restore or....search on for new
I'm really enjoying challenge tho! Itll be very rewarding to see it done
Similar Threads for: 1984 Honda XR 250-new project-full restoration!
My 2005 CR250 Restoration Project MxSkillz Dirt Bike Restorations and Builds 45 11-17-2013 10:00 AM
1984 CR500R Project Bike Tim91 2-Stroke Dirt Bikes - Honda 6 07-29-2013 01:26 AM
My 1984 RM125 project DKSA Vintage Riding 6 01-16-2010 08:03 AM
The 1984 CR80 Pre-Restore project mrstein69 2-Stroke Dirt Bikes - Honda 7 09-22-2009 01:18 AM
Project Bike- 1984 Honda XR80 ccra92 Classified Ads 0 12-09-2006 10:09 AM
