Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Motorcycle Forums > 4-Stroke Motorcycles - Suzuki
RMZ-250(2007) Valves, Replace or not?!
This is a discussion on RMZ-250(2007) Valves, Replace or not?! within the 4-Stroke Motorcycles - Suzuki forum, part of the 4-Stroke Motorcycle Forums category; Hej guys! I have an RMZ-250(2007), 80-90 hours in it(approximately) but it is a hobby bike. Last season was my ...
Old 11-17-2008, 02:42 PM
Last Online: 11-17-2008 02:42 PM
Default RMZ-250(2007) Valves, Replace or not?!
Hej guys! I have an RMZ-250(2007), 80-90 hours in it(approximately) but it is a hobby bike. Last season was my first in MX. This year im a bit better. Im asking for some help! Its for sure that I have to adjust the valve clearance but Im wonder that I need to replace them at all? And what about the piston? Should it be replaced or what determines the replacement of the piston or the valves? thanks in advance
adam
Old 11-18-2008, 08:05 AM
DRGSin393's Avatar
Super Moderator
I slept at a Holiday Inn Express last night. Ill give it a stab. Def check the clearances on your valves. You wont need to replace them unless theres something wrong with them or you want to upgrade them to a better quality valve. A compression check will tell you if your rings need changing and you can mic the piston to check if youre within normal specs.
Old 11-18-2008, 10:45 AM
pjg351's Avatar
Tie me Kangaroo down sport
Last Online: 11-19-2009 06:34 PM
With that amount of hours on your bike, and intending to race it. I would definatley replace the piston and at the least shim the valves if required, but for peace of mind i would replace them as well and the valve springs, if your going to race the whole season.
Similar Threads for: RMZ-250(2007) Valves, Replace or not?!
When do you replace reeds aaron1473601 General Discussion 3 09-04-2008 08:04 PM
97 cr 80 Replace Rear Hub?? kawamama3 2-Stroke Motorcycles - Honda 9 03-04-2008 04:24 PM
Should you replace an O or X ring chain everytime you replace your sprockets? CaRdinalFan450 General Discussion 7 11-11-2004 04:13 AM
Do I need to do a Top End or replace Reeds? hevnsnt 2-Stroke Motorcycles - Yamaha 27 02-27-2004 08:48 PM
Should I replace the piston on my 02 CR 250? Dart440 2-Stroke Motorcycles - Honda 23 12-25-2003 08:58 PM
