Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Dirt Bike Bike Forums > 4-Stroke Dirt Bikes - Suzuki
Old 05-15-2011, 03:53 PM
Sgtcat09's Avatar
Last Online: 07-16-2011 03:11 PM
Default Gas coming out of overflow??
The overflow on my DRZ is just pouring gas out of it. I tried tapping on it, i took the carb apart twice and cleaned it really good, and after riding for 2+ hours it's still coming out, not slowing at all. I tried messing with the float, it moves up and down fine when not on the bike, the pin isn't bent or anything. I don't know what else to try. What's making it do that?Does it need a new float or something, or is it a simple fix?
Thanks guys.
(It's a mikuni carb, if that matters)
Old 05-15-2011, 04:02 PM
peaceflood's Avatar
Last Online: 08-16-2016 12:23 PM
i guess i would drain the gas and take the carb off and shake it up and down to make sure the float could move freely, if that checked out okay i would take the float bowl off and check the inlet needle thing that stops and starts the flow of gas into the carb and make sure it is seating properly.
Old 05-15-2011, 06:56 PM
char393's Avatar
cha cha
Last Online: 04-27-2018 09:36 AM
How To Set Your Motorcycle Carburetor Float Level
Old 05-15-2011, 08:03 PM
bbrmotosports's Avatar
Rockin A class
Either adjust the float to the correct height. Or the needle and seat are worn out would be my guess
Old 05-16-2011, 02:06 PM
Sgtcat09's Avatar
Or missing completely...
I'm guessing that would be the problem...
Old 05-17-2011, 03:43 PM
Sgtcat09's Avatar
Well I ordered a rebuild kit, figured I might as well rebuild it instead of just ordering the needle/seat assembly thing. Should be here by the weekend, hopefully I'll make it to the track again this weekend.
Old 05-17-2011, 04:20 PM
CHRIS_NM1's Avatar
Last Online: 08-01-2013 12:25 PM
Your float needle is not seating properly....you did the right thing in ordering a rebuild kit. Once installed it will be like new.
Old 05-17-2011, 04:24 PM
Sgtcat09's Avatar
Actually the float needle is missing.
Just got the rebuild kit in today.I'm gonna rebuild it tomorrow and see how it goes.Also went up to the next size main jet, I heard they come a little lean from the factory.
Similar Threads for: Gas coming out of overflow??
Fuel overflow....why?? spartanbiker_117 2-Stroke Dirt Bikes - Honda 12 06-04-2008 03:15 PM
2000 yz426f fuel coming out of overflow lines DavidBeebe 4-Stroke Dirt Bikes - Yamaha 2 08-05-2007 03:06 PM
coolant coming out overflow 03cr125 2-Stroke Dirt Bikes - Honda 7 02-22-2005 08:17 PM
Gas out overflow jharvey1309 2-Stroke Dirt Bike Forums 4 06-29-2004 10:05 AM
gas overflow crdemon 2-Stroke Dirt Bikes - Honda 3 04-21-2004 06:22 PM
