Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Dirt Bike Bike Forums > 4-Stroke Dirt Bikes - Suzuki
Old 03-22-2012, 07:22 AM
Last Online: 11-28-2012 12:43 PM
Default Can't get my rebuilt motor to start
I just rebuilt my 2004 rmz 250 I have everything together I have the timing set right I have a spark and I have fuel from the carb.
I had my buddy pull me down the road and I was able to get it to start and run but not very well it will die as soon as I pull in the clutch. Once I got pulled to about 20 mph I could actually drive it but it sounded like it was begging for fuel or something.
Any help would be appreciated thank you
Old 03-22-2012, 08:52 AM
dirthw84's Avatar
Last Online: 06-20-2012 03:00 AM
Should have got a 2 stroke
Old 03-22-2012, 09:25 AM
if it sounded like it was begging for fuel, it may have been doing just that. air leaks can make it seem like that sometimes. at TDC on the compresstion stroke do you have clearance on all the valves?
Old 03-28-2012, 12:00 PM
I checked my valve Clarence again and it all seems good
The bike will start and run for 2 seconds after I kick it if I hold the throttle wide open.
Old 03-28-2012, 02:05 PM
doesnt sound fuel starved then.
Old 03-28-2012, 02:37 PM
Last Online: Today 12:54 PM
Default OK
Ok, how long was the bike apart or not running during the rebuild?
Is you spark Blue?
Was the stator put back in corectly?
Are you 100% sure the valves are set correctly?
Are you 100% sure the cam timing is 100% correct?
Was there fuel left in the carb while the engine was being rebuilt?
Have you tried to clean the pilot jet in the carb?
Tere are so many things it could be but is would be my order of checks.
1. Cam timing
2. Valve clearances
3. Spark plug (new)
4. Remove the pilot jet from the carb and make sure the center orfice is open.
5. Set your fuel screw to about 2 turns CCW from fully seated.
Old 04-12-2012, 01:14 AM
Tr0jan's Avatar
Last Online: 01-02-2014 03:29 AM
Is you spark Blue?
1. Cam timing
2. Valve clearances
3. Spark plug (new)
Sounds to me like the cam timing is out by 1 tooth. Recheck the markings.
Old 04-12-2012, 01:35 AM
If you find your cam timing is out you will want to make sure the valves didnt hit the piston. if they did, they are almost certainly not sealing anymore.
Old 04-13-2012, 11:55 AM
The cam timing is perfect I checked it and rechecked it
If the exhaust valve clearance is too small could it cause this to happen?
Old 04-13-2012, 12:06 PM
farmercrf450x's Avatar
Last Online: 04-19-2013 06:09 PM
Yep that could be it, anytime valve lash gets off does weird stuff and not all bikes react the same.
Tags
250, rmz, start
Similar Threads for: Can't get my rebuilt motor to start
places to get honda cr125 motor parts and motor rebuilt madmanwinkey 2-Stroke Dirt Bike Forums 6 07-01-2011 09:15 PM
Rebuilt but won't Start. No Fuel? hybridpower 2-Stroke Dirt Bikes - Yamaha 17 06-22-2007 04:47 PM
05 KX250 motor, YZ250 motor, what is the difference UnsafeHaven 2-Stroke Dirt Bikes - Kawasaki 2 09-19-2005 11:35 AM
1999 CR250 Rebuilt Motor maf1188 General Discussion 1 01-11-2005 11:00 PM
250f motor.....this yamaha motor is bulletproof? broorda 4-Stroke Dirt Bikes - Yamaha 36 01-16-2004 08:11 PM
