This is a discussion on 6x8 atv/snowmobile trailer within the Miscellaneous forum, part of the Classified Ads category; I have a 6 foot wide by 7 1/2 feet long flatbed tilt trialer. Trailer was a 6x8, but I ...
I have a 6 foot wide by 7 1/2 feet long flatbed tilt trialer. Trailer was a 6x8, but I cut the bad steel out and replaced it with newer steel and moved the center of gravity to fit the movement of the newer steel.
I also replace the wood, I put the good 3/4 inch on there and then put a layer of deck water sealer on it. As you can see by the pictures, I used 1/4 angle iron for the shackles, tongue, and the place where you put the pin in to secure the trailer to the tongue.
I did put the original sides back on, you can see the holes where I have moved the steel.
I also put on a new coupler, chains, light, and a jack with a wheel. The bearings are new. Takes a 1 7/8 ball. I have a spare tire mount, still new in the box. Comes with a spare also.
I put alot of money into this trailer and then found a landscaping trailer to better fit my needs, so this has to go...
