Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Motorcycle Forums > 4-Stroke Motorcycles - Kawasaki
what is a baffle
This is a discussion on what is a baffle within the 4-Stroke Motorcycles - Kawasaki forum, part of the 4-Stroke Motorcycle Forums category; ok i feel dumb for asking this but what is a baffle i read on tt to cut it out, ...
Old 08-10-2005, 08:32 PM
klxrider3214's Avatar
Last Online: 07-03-2009 01:38 AM
Default what is a baffle
ok i feel dumb for asking this but what is a baffle i read on tt to cut it out, can anyone show me a picture of one on a klx 125l
Old 08-10-2005, 09:09 PM
Default Re: what is a baffle
that is why i need to know
Old 08-11-2005, 07:44 AM
Thumprding's Avatar
Last Online: 01-09-2007 07:36 AM
A baffle is a part of a muffler inside the canister. A baffle redirects the exhaust flow inside the muffler to break up the exhaust pulses and reduce the energy of the pulse before the exhaust gases exit the muffler.
Imagine a round section of pipe with two end caps. In both end caps you cut a hole and put in a short section of pipe. So you have this tube with two short pipes. One goes into and one goes out of and nothing inbetween.
Baffle.
Take a round steel plate with a diameter equal to the inside diameter of the main pipe. Drill a bunch of holes in it. Install the plate in the large pipe in the middle inside. The exhaust gases now flow from the smaller pipe into the larger pipe then it must flow thru the small holes and then back together to flow out of the muffler. The plate is known as a baffle plate. Simple muffler, sort of hurts performance but is effective at breaking up the pulses.
Next
Take the same design but make these changes.
Goes into pipe now extends almost all the way to the goes out of pipe and the baffle plate is pretty close to the exit. The center goes into pipe is welded to baffle plate but the baffle plate does not have a hole in the middle. Take the goes into pipe and drill a bunch of small holes in it that when installed will be in the canister. Towards the end of pipe drill bigger holes. Now wrap the section of the inlet pipe with the small holes with fiberglass or similar high temperature batting. Shove the baffle plate and the inlet pipe inside the canister then put on the inlet end cap and seal the end cap to the inlet piping. What you have made is a perforated core glass pack muffler with a baffle plate. The packing absorbs and dampens energy from the pulses and the baffle break up the pulses. You will have about the same performance as the first design but it will be quieter.
If you drill a hole in the center of the baffle plate you will decrease flow resistance at the cost of increased noise.
Old 08-11-2005, 11:44 AM
can you show a pic
Similar Threads for: what is a baffle
removing baffle Vinny3299 ATV/UTV - Yamaha 1 07-14-2005 10:57 PM
Cant get my Baffle off quadrider32 ATV/UTV - Yamaha 8 05-31-2005 11:51 PM
baffle burstonecr250r ATV/UTV - Suzuki 7 02-06-2004 10:04 PM
Pulled Baffle off 04' Raptor roadrash ATV/UTV - Yamaha 6 12-30-2003 05:05 AM
how do take off the baffle and jet the the carbuerator 04'yfz4u ATV/UTV - Yamaha 14 11-14-2003 04:05 PM
