Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Dirt Bike Bike Forums > 4-Stroke Dirt Bikes - Kawasaki
Old 11-23-2018, 08:18 PM
Last Online: 11-24-2018 02:50 AM
Default Kx250 engine oil
about to do my 1st oil change, cant find anywhere that says what oil to use? also any1 know what filter ?
no trolls please
p.s. 4 stroke 2017 kx250
Old 11-23-2018, 08:43 PM
Last Online: Today 04:02 PM
The owners manual should have that info in it.
Look oil threads always bring a lot of mis-information to thread and a lot of good , bad and incorrect info will be included. I will not get involved in that.
So, what ever oil you use, be sure it is "wet clutch" approved. Understand almost no auto oils are rated for that and most will help you burn up your clutch quickly due to friction inhibitors added to them.
The oil should have a round seal on it with the rating on the top part of the seal and the bottom part of seal should be blank. If anything is in that bottom part of the seal, it will not work for you.
Contact your local dealer and see what he suggest.
Old 11-23-2018, 09:15 PM
Thanks this helps alot
Similar Threads for: Kx250 engine oil
95 KX250 Engine 01 KX 250 Frame mrchavez723 2-Stroke Dirt Bikes - Kawasaki 0 05-01-2013 05:13 PM
'01 KX250 engine compatibility jeffascmclaren 2-Stroke Dirt Bikes - Kawasaki 1 03-19-2012 10:02 PM
Kx250 engine cases?!?! kxr1der87 2-Stroke Dirt Bikes - Kawasaki 2 02-23-2009 01:22 PM
99 KX250 engine noise Jim Howell 2-Stroke Dirt Bikes - Kawasaki 7 02-18-2007 06:50 PM
2002 kx250 engine swap? sircrashalot 2-Stroke Dirt Bikes - Kawasaki 0 10-04-2006 12:13 PM
