Quantcast kawasaki KX450F
Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Motorcycle Forums > 4-Stroke Motorcycles - Kawasaki
kawasaki KX450F
This is a discussion on kawasaki KX450F within the 4-Stroke Motorcycles - Kawasaki forum, part of the 4-Stroke Motorcycle Forums category; Hey I need help. I have a 2008 KX450F and having problems. The bike starts fine until it gets warm ...
Old 02-28-2008, 05:50 PM
Last Online: 03-02-2008 04:30 PM
Unhappy kawasaki KX450F
Hey
I need help. I have a 2008 KX450F and having problems. The bike starts fine until it gets warm then it just shuts off. I have tried everything. I checked the kill switch, drained the carberated and cleaned it, airfilter is brand new, changed the plunger in the carbarator. I havent ridin for 4 weeks now I have workd at least 24 hours on it trying to figure out whats wrong. Can anyone help?
Thanks a lot.
Old 02-28-2008, 09:53 PM
Shoei_391's Avatar
Rebuilding the KDX
Last Online: 11-29-2008 12:18 AM
Default Re: kawasaki KX450F
What color is your plug? Maybe you have rich jetting...?
Old 02-29-2008, 03:31 PM
Dano426's Avatar
Last Online: Today 11:10 AM
When cleaning the carb, make sure you are using carb cleaner and an air compressor to blow out each jet.
Have you tried a new plug?
Old 02-29-2008, 08:42 PM
Big Maico 393's Avatar
Super Moderator
Last Online: Today 11:40 AM
OK been their done that on my KTM!
First check to see if your valves are set right, if there just a tiny bit tight when the motor gets warm you won't have a good seal on the cylinder & the motor won't start until it cools off.
If that doesn't fix it look at your ignition system, starting with the plug & plug cap! also check to see that your coil is grounded well with no rust.
You might even want to check the plug wire where it go's into the cap & see if the end of the wire is corroded. if it is just cut a tiny bit & put it back & you should be good to go!
Old 03-02-2008, 04:29 PM
Yeah I put a new one in
Old 03-02-2008, 04:30 PM
Thanks for the help Ill try what you said and Ill get back to you
thanks a lot
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: kawasaki KX450F
New guy on a KX450f soon 2 B in Fla. TNTRACING Member Introductions 9 01-11-2007 02:27 PM
kx450f 3taz11 4-Stroke Motorcycles - Kawasaki 2 02-03-2006 02:50 AM
New KX450F-SR LoKi 4-Stroke Motorcycles - Kawasaki 24 03-17-2005 08:00 PM
KX450f 1989kx125 General Discussion 14 03-14-2005 05:02 PM
KX450F ProAMA725 General Discussion 9 02-17-2005 11:25 AM
vB.Sponsors
Page generated in 0.16510 seconds with 12 queries
