08 kawasaki 250f carby modThis is a discussion on 08 kawasaki 250f carby mod within the 4-Stroke Motorcycles - Kawasaki forum, part of the 4-Stroke Motorcycle Forums category; I just installed a JD jetting kit into the new 250f and this is what changed. The pilot went from ... |
| I just installed a JD jetting kit into the new 250f and this is what changed. The pilot went from a 40 to 42 the main from a 182 to 190 and a different needle with the clip 5 from the top. the air mixture screw 1and 3/4 turns out. Now the other little trick was to hook a rubber o ring over the accelerator pump screw adjuster and the other part that makes contact with it, (like a set of points) to make it put a little more pressure back on the pump for a quicker throttle opening. Did it all work? "YOU BET IT DID" it's as crisp as you would ever get it and the power delivery is awesome! Don't hesitate in getting one they are well worth it. PS: this adjustment may not suit all areas different jetting for higher above sea levels, but it tells you all in the kit. Also this will work on 06-07 as well. |
With the jd needle we were getting a flat spot bog especially after landing a jump . Changing the clip position didn't help. The hard wiring of the accelerator pump screw seems to work just fine and allows a very smooth and quick throttle response. I think we will try the 190 main jet on heavy sandy tracks. Anyway it seems to be running as good as we can get it at this stage. |
| Carby issues | jesta27 | General Discussion | 3 | 01-28-2009 08:33 PM |
| cr85 carby settings | Adrian14 | 2-Stroke Motorcycles - Honda | 0 | 05-10-2008 08:46 PM |
| Carby help | KX12five | 2-Stroke Motorcycles - Kawasaki | 1 | 11-04-2007 07:25 AM |
| 2004 250F Honda VS Kawasaki | Charles4x4 | 4-Stroke Motorcycles - General Discussion | 26 | 07-09-2004 03:30 AM |
| kawasaki 250f? | Jason | 4-Stroke Motorcycles - Kawasaki | 25 | 10-22-2003 02:18 PM |
