07 kx250f knockingThis is a discussion on 07 kx250f knocking within the 4-Stroke Motorcycles - Kawasaki forum, part of the 4-Stroke Motorcycle Forums category; The other day, my sons bike overheated. There was blue smoke and a burnt odor. From looking at the plug, ... |
| The other day, my sons bike overheated. There was blue smoke and a burnt odor. From looking at the plug, it was running very lean. I relaced the rings and the main jet but there was a knock in the motor and still running lean. I check further and found some play in the connecting rod big end and the left crancksaft bearing. I put in a hotrod crank assembly and oem cranckshaft bearings. I still found a bit of play in the left bearing even if it fit thight on the crank and in the crankcase. After re-assembling, I still have the same knocking and still runs lean. I double checked timing chain and everything. I starts and runs good. I tried another crankshaft bearing and it still has some play. Is this normal? If so, what would be the knocking noise? THANKS! |
| well the rod should have left to right play, but up and down play is bad.. don't know which motion u are referring to but what happened to mine was that the bearing housing cracked and was allowing the rod and bearing to slide around... if u are running lean, take apart the carb and do an overhaul on it with some carb cleaner and compressed air, there might be something stuck in one of ur jets... -nic |
| New CR250 knocking | Hawgeater | 2-Stroke Motorcycles - Honda | 16 | 09-30-2008 05:20 PM |
| TTR125 knocking HELP! | CR80Rider | 4-Stroke Motorcycles - Yamaha | 0 | 06-18-2008 06:04 PM |
| 05 yz 125 knocking | bcsyz125 | 2-Stroke Motorcycles - Yamaha | 4 | 01-28-2008 10:39 AM |
| KX250 knocking | 2000kx250 | 2-Stroke Motorcycles - Kawasaki | 21 | 01-06-2007 05:20 PM |
| Funny sound.... Knocking? | Dirtjump9 | 2-Stroke Motorcycles - Suzuki | 14 | 03-25-2006 02:38 PM |
