Putting in a new top endThis is a discussion on Putting in a new top end within the Mini Motorcycle Riders forum, part of the Dirt Bike - ATV - Suspension Forums category; How difficult is it to put in a top end on a 1999 YZ 80?
Thanks,
241... |
| How difficult is it to put in a top end on a 1999 YZ 80? Thanks, 241 |
| Not difficult at all...esp since a mechanical putz like me can do it. Just get your manual out, the correct tools, order all the parts and clean up a work area. This video is a big help also. Good luck and take pics along the way. And as always, dont hesitate to ask questions. A couple things to keep in mind -once the cylinder is removed, stuff a rag down in the case so nothing falls into it. Watch out for those pesky circlips, also! -the rings go on a certain way so be aware of that. -this would be a great time to check out your reeds-they should lay perfectly flat with no daylight showing. [Only registered and activated users can see links. ] Last edited by DRGSin393; 08-12-2008 at 09:01 AM. |
| My sister rode a 93 yz80 to get her started on tracks and from what I remember they dont even have a powervalve so there isnt much in the top end but the jug,piston,piston pin,and some gaskets then the head.O and a little bearing the goes on the pin.Make sure you clean everything real good,I like to use carb cleaner or starting fluid. |
| putting the yz back together | misfitsbob | General Discussion | 4 | 01-26-2008 04:25 AM |
| putting lights on | yamaha86421 | 2-Stroke Motorcycles - General Discussion | 5 | 01-15-2008 03:34 PM |
| putting on new graphics | scuba steve | General Discussion | 4 | 06-28-2007 08:55 PM |
| Putting up Sigs? | cr2504life | General Discussion | 3 | 06-17-2004 12:04 PM |
| Putting a light on.............. | Spitfire | 2-Stroke Motorcycles - General Discussion | 17 | 04-24-2004 11:14 PM |
