1979 Suzuki DS80 oil/fuel Ratio ??This is a discussion on 1979 Suzuki DS80 oil/fuel Ratio ?? within the Mini Motorcycle Riders forum, part of the Dirt Bike - ATV - Suspension Forums category; I am needing help on what gas oil ratio i need to mix for my sons 79 ds80 Anyone got ... |
| I am needing help on what gas oil ratio i need to mix for my sons 79 ds80 Anyone got a clue? and what brand/type of 2 cycle oil i have some tc w3 says will work for tcw1 tcw2 and tcw3 will this work? as well as it wont run unless i pull out the choke . if i push it in it will some times just die other times it will idle WAY high then die depending on engine temp what would do that ? Thanks for any help in advance. |
| I may be of some help to you as I have always been able to keep my children's Brap Brap's running. First find a manual for this machine if you can. These are your bible. Now as far as mixture ratio 32:1 will work on almost anything. 4OZ oil to 1gal fuel. I like Spectro or Castor927 for premix. Be sure the oil you purchase is for premix. There is a consistancy differance between oil for injector and premix. Next, Take off the carburator and take it apart fully and clean with solvent such as gas or an aquious cleaner. Stay away from Brakecleaner as it tends to melt any plastic or rubber parts. When you take the carb apart you really dont need to remove the jets. Then blow down the parts and the carb body with high pressure air. Be sure you can see light(flashlight) thru the jets. If you cant see light the jet is still dirty. If you dont have use of a compressor for air get a couple cans of that air used to clean off computer's. I do not know your mechanical abilities but this is pretty basic. When you assemble the carb just set the idle air screw or needle valve as some call it.(the pointy screw with the spring on it) as follows. Screw it all the way in then back it out 1&1/2 turns out. this is a general setting that will get you going. Remember when installing needle vlave DO NOT CRANK IT TIGHT, just turn till you feel it bottom out. Before you put the carb back on clean the air-box and air filter well. Now grab a beverage of your choice and have at it. No rocket science here, just another fatherly duty. |
| 1981 SUZUKI DS80 PARTS | oscar442 | Motorcycles & ATV's | 0 | 09-10-2008 06:32 PM |
| Service Manual 1992 Suzuki DS80 | loweyj | MC & ATV Parts & Accessories | 0 | 01-06-2008 07:31 AM |
| Headlight for Suzuki DS80 | Ks Dad | Mini Motorcycle Riders | 2 | 12-19-2007 02:22 PM |
| 1979 Suzuki PE175 air filter compatability? | ncoop23 | 2-Stroke Motorcycles - Suzuki | 0 | 06-03-2007 09:56 AM |
| F/S Suzuki DS80 | islandsurfer | Motorcycles & ATV's | 0 | 03-30-2005 02:51 PM |
