Quantcast New Rider
Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > Member Introductions
New Rider
This is a discussion on New Rider within the Member Introductions forum, part of the Dirt Bike - ATV - Suspension Forums category; New to the Forum Own a 01 CR 250R and I and turning it into a TRAILMONSTER!!!! I read the ...
Old 11-30-2008, 07:49 AM
Last Online: 12-04-2008 10:45 AM
Default New Rider
New to the Forum
I read the forums on turning a MX bike into a woods bike and how much it will
cost. However, I got a good deal on this bike so I can splurge to make it woods carving machine.
Stats on the Bike:
New Engine and clutch!!!!!
FMF Gnarly pipe
Renthal Bars
WWR radiator guards
Metal Melissha graphics
Front forks redone by BBR-too stiff for woods-settings backed all the way-need input here-front end needs to be softer
Rear shock rebuilt for my weight and riding and new Pivot works bearing kit installed
New x-ring chain and sprockets 13/53-can you say SNAP WHEELIES!!!!!
New Dunlop tires-too hard for woods riding-need input on better tires
New Acerbis bark busters
New clutch handle
New Kickstarter
New Oversized Footpegs
New MSR skid plate
New MSR shifter
New Pivot works wheel bearing kits
New Pivot works linkage bearings kit
New Pivot works swingarm bearings kit
New Carb vent tubing with loop seal put on float bowl overflow-for woods riding
New Engine Ice anti-freeze
New MSR Steel Rear Wheel Axle spacers
New Rear Brake Disc Rotor-mud style
New MSR Axle blocks
Need help with the Following :
Gas tank selection-Clarke or IMS???
Weight of flywheel weight 9-10-11oz????
JD Jet Kit-will be riding lots of technical trails from 1K to 6K in alt-yes we have lots of mountains on the North Olympic Pennisula. Need low end power control and need to make the best use of fuel. This thing goes through gas like it's free right now.
Reed Valve-who makes the best valve for low end torque and power???
Lighting Kit???
Kickstand-no looking for trees to lean up against is not fun and the bike usually falls over anyway!
Front Fork Valving and spring selection- I live near Seattle-anyone in this area???
Better Seat-my tushy huuuuurts after a long day in the saddle!!!!!
Any help would be greatly appreciated.
Thanks, Aden Rich
Old 11-30-2008, 07:57 AM
YZ 250 RIDER's Avatar
YYYYZZZZ!!!!!!
Last Online: 01-01-2009 09:42 PM
As for the tires I have a kenda millville on the front of my 04' KX250 and a kings tire on the rear, I'm not sure what model. If you search for threads on "what tires to use" you should be able to find some useful information.
Old 11-30-2008, 10:34 AM
AJ_YFZ's Avatar
MX JUNKIE
Last Online: Yesterday 03:40 PM
Welcome to ...
Old 12-01-2008, 06:02 PM
I've been RM-Zedded
Last Online: Yesterday 05:53 PM
Welcome to , glad to have you.
Old 12-02-2008, 07:53 AM
Florida 393's Avatar
Semper Fidelis
Last Online: Yesterday 12:58 PM
Usflag
Welcome aboard ATM, agrich! Souinds like you are building a sweet woods weapon there. I am sure the woods guys like Macho, etal will chime in on your questions. Plenty of goos experience here to lean on.
Bill
Old 12-02-2008, 08:15 AM
The Kimster's Avatar
Last Online: Yesterday 12:27 PM
Welcome to !
Old 12-02-2008, 09:29 AM
crfjedi393's Avatar
Obi Wan Kenobody
Last Online: Yesterday 05:18 PM
Old 12-02-2008, 09:32 AM
KKXR400R's Avatar
V67X
Last Online: Yesterday 08:15 PM
Lighting Kit???
Thanks, Aden Rich
Sounds like a nice little project. I have a question..What are WWR rad guards? I've never heard of them.
As far as your gearing, that's alot of low end. I would drop down to 50 or 51 (stock) and see if it's a little more manageable. The 11 oz flywheel weight works well with my gearing (14-48) but you may have to play around with the rear sprocket to see if it works with your riding style. IMS only sells a 3.9 gallon tank and Clarke has a 3.1 (I think). The IMS tank didn't fit well and the triple clamps hit the top of the tank. I switched to the clarke a little while back...Lighter, fit's well and less bulky. I have had no problems with my seat foam but had a few people say that Guts racing makes a softer seat foam and they like it. Pro Moto billet makes a kickstand. You can also get on that just bolts on to the swingarm. Lighting kits...good luck. I have been searching for a while and I think they only make a 35 watt system...better off taping a flashlight to your helmet. Hope this helps.
-Kevin-
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: New Rider
UK Rider badge100 Member Introductions 0 11-19-2008 07:12 AM
Another rider down!!! Drew778 General Discussion 7 06-19-2007 07:18 PM
New MX rider - YZ 125 Malcolmv8 Member Introductions 14 05-18-2007 06:43 AM
Pro Rider sig? Supermoto Photo & Video 2 10-09-2005 06:40 PM
old street rider, new dirt rider, what bike? newdirt General Discussion 7 01-06-2004 12:51 AM
vB.Sponsors
Page generated in 0.22102 seconds with 12 queries
