Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > Member Introductions
New to ATM and riding
This is a discussion on New to ATM and riding within the Member Introductions forum, part of the Dirt Bike - ATV - Suspension Forums category; hello from manitoba. i ride a 2002 yz125 i'm wondering what i need to do to prep my bike for ...
Old 09-30-2009, 08:12 PM
slama4's Avatar
Last Online: 11-18-2009 07:33 PM
Default New to ATM and riding
i'm wondering what i need to do to prep my bike for winter storage.
thanks
Old 09-30-2009, 08:16 PM
AJ_YFZ's Avatar
MX JUNKIE
Last Online: Yesterday 11:17 PM
Welcome to
Old 09-30-2009, 08:31 PM
MXtras's Avatar
Manufacturer
Welcome to the site!
As far as what to do for storage - drain the tank and carb and check your antifreeze concentration or simply drain it completely to eliminate the possibility of freezing.
Other than that - count the days until you can think about riding again!
Scott
Old 09-30-2009, 08:48 PM
slama4's Avatar
how do i drain my carb? and is it also possible to use some sort of fuel stabilizer and run it through the system then store with a full tank of fuel?
Old 09-30-2009, 08:58 PM
Macho393's Avatar
CROSSTHREADED RACING
start your bike with the gas pitcock turned off is the easy way. Let it run until it dies.Your gas will not be good over the winter.
Old 09-30-2009, 11:33 PM
MXtras's Avatar
Manufacturer
I would store empty.
Pull the fuel line off the carb, put the end in a gas can, open the petcock and drain it. Once no more fuel comes out, close the petcock and lay the bike over on it's left side - this will get the fuel out of the right side of the tank (there's a hump in the tank) and repeat the draining.
Laying the bike over on each side will effectively remove 90% of the fuel from the carb, too, but it's not hard to pull the bottom plug off the carb to get it all out.
I would not suggest using a stabilizer. I have no personal experience with it when mixed with premix, but $10 worth of mixed fuel is nothing in comparison to what's at risk when you run it next spring.
Scott
Old 09-30-2009, 11:42 PM
yzernie's Avatar
Moto Geezer
Good suggestions above and welcome to !!! If I was going to store for a long time I's take the spark plug out and spray a little oil into the cylinder and slowly move the kick starter a couple time to get a good coating on the walls.
Old 10-01-2009, 06:06 AM
Last Online: 10-11-2009 07:12 AM
I have been reading though the manual that I was so greatfully directed to and it suggests a few things but draining the fuel from the carb and tank are on the top. [Only registered and activated users can see links. ] Get it and read it its got heaps of good stuff in it. If you have the paper manual that comes with the bike then just read it.
Old 10-01-2009, 12:23 PM
slama4's Avatar
i tried draining the carb before by pulling the bottom plug, but was only stripping the bolt, it wouldnt move at all
Old 10-01-2009, 12:35 PM
I've been RM-Zedded
Last Online: Today 03:53 AM
Welcome to
Are you removing the big nut (the 17mm one)?
Old 10-01-2009, 04:44 PM
slama4's Avatar
not sure size, but yes it was a big one directly on the bottom. also i just changed my tranny oil and the old oil came out greyish. is this normal?
Old 10-01-2009, 09:03 PM
MXtras's Avatar
Manufacturer
Grey? Kinda foamy? If so, you likely need a waterpump seal and bearing. Could be the case cover gasket but not as likely as the waterpump seal.
Some oils could come out grey with a lot of use - kinda depends on what it looked like when it went in.
Scott
Old 10-01-2009, 10:39 PM
slama4's Avatar
this is my first tranny oil change since i've had the bike. no, it was not foamy, and the previous owner said he had just went through everything on the bike, replaced wheels bearings and fork seals, did a leak test on the motor, etc., etc., and put motor oil in the tranny if this makes a difference?
Similar Threads for: New to ATM and riding
fun day of riding the_privateer Photo & Video 5 06-27-2007 04:36 AM
Kansas - Carbondale Riding Park - Open Riding Area Grashopr USA - Central States 2 06-08-2007 08:45 AM
May Pit Riding quadrider32 Photo & Video 5 05-25-2006 03:12 AM
Less Likely To Be Injured Riding an ATV Than Riding a Bicycle ekholms-mx-farm General Discussion 22 12-31-2005 04:08 PM
Kansas - Perry Lake Riding Area - Open Riding Grashopr USA - Central States 0 02-26-2003 01:18 AM
