Quantcast ktm250sxf jetting issues
Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Motorcycle Forums > 4-Stroke Motorcycles - KTM
This is a discussion on ktm250sxf jetting issues within the 4-Stroke Motorcycles - KTM forum, part of the 4-Stroke Motorcycle Forums category; i have a 2006 ktm 250sxf and i am having some major jetting problems. whenever i try to lug a ...
Old 06-17-2007, 10:46 PM
Last Online: 11-18-2008 09:03 PM
Default ktm250sxf jetting issues
i have a 2006 ktm 250sxf and i am having some major jetting problems. whenever i try to lug a taller gear my bike gets a serious case of the coughs before finally kicking in at high rpm. the additions i have are a dr.d pipe and a boyesen quickshot accelerator pump cover . also i am running a 175 main and the optional OBETN neddle and the clip is on tne 5th position from top. i cuyrrently ride from 2000 to 3000 feet evelation and there is almost no humidity(and anywhere from 90 to 110 degrees F).any info would be greatly appreciated . thanks
P.s. would one tooth bigger sprocket on the rear make the difference
Old 06-18-2007, 11:26 AM
Dano426's Avatar
Last Online: Yesterday 11:10 AM
Default Re: ktm250sxf jetting issues
This does not sound like a jetting issue, but I could be wrong. You need to ride these 250Fs like a 125 2-stroke. You should always be half way or full throttle. If you are lugging the motor there is no power. Try using you clutch more when it is lugging.
Try adding on tooth to the rear sprocket. It will help your low end, but loose some top end. I am a 200lbs guy and adding two teeth to the rear sprocket helped me, but I am always riding in the tight trails and on smaller MX tracks.
Hope that helps and welcome to ATM
Old 06-18-2007, 12:21 PM
Big Maico 393's Avatar
Super Moderator
Last Online: Yesterday 09:36 PM
Jim:
First off welcome to
You'll need to read these post's
Carb setup 101
ACCELERATOR PUMP SET UP 101
That should put you on the right track!
Old 07-02-2007, 02:52 PM
thanks for your input but the problem ended up being the needle. I had the clip 5th from top, and i went to 4th from top and found a big improvement, then i decided to try one more up and know my 250f runs like a champion. also i re ajusted my accelerator pump to boyesen's recomended specs and that also helped some. as for the rear sprocket, one tooth larger helped close the gaps from 2nd to 3rd and 3rd to 4th.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: ktm250sxf jetting issues
CRF jetting issues xxxshiftxxx 4-Stroke Motorcycles - Honda 8 04-02-2007 03:57 PM
CLUTCH ISSUES Michael Parker 2-Stroke Motorcycles - General Discussion 4 03-05-2006 09:36 PM
Ebay KTM250SXF Cheap? Crazy Motorcycles & ATV's 16 07-17-2005 04:05 PM
03 KX125 jetting issues KKXR400R 2-Stroke Motorcycles - Kawasaki 3 01-08-2004 10:10 PM
vB.Sponsors
Page generated in 0.18880 seconds with 12 queries
