525 exc valve adjustmentThis is a discussion on 525 exc valve adjustment within the 4-Stroke Motorcycles - KTM forum, part of the 4-Stroke Motorcycle Forums category; Could anyone offer a little help into the proper procedure on adjusting the valves on a 05 525 exc? Thanks... |
| Could anyone offer a little help into the proper procedure on adjusting the valves on a 05 525 exc? Thanks |
| You can bet somebody will. I can't help you at all. I have only owned Honda's. I'm thinking the KTM's have an external adjuster on them. Or am I confused? Either way, Big Maico or a few others will be on before too long to answer your question. Just be patient. BTW, Welcome to |
[Only registered and activated users can see links. ] |
| You are just the helpful one tonight aren't you |
I'm sorry, I just know a thing or three about KTM's I also thought that was what |
| Re: 525 exc valve adjustment Sledhedz, Since the others were busy ragging on each other Bill |
| Once again...I love this place |
| For some reason [Only registered and activated users can see links. ] does not work. It says the topic is closed + it will not take a yahoo account, says that free e-mail is not allowed. Is there a way to open it that you know of? I did pull off the valve covers and they seem tight, but I would imagine that I would need to have it on tdc to do each valve? Thanks for the fast reply!! |
| Re: 525 exc valve adjustment Sled, Let me see if I cna help out. A lot of sites have banned Yahoo accounts due to spam and punk users. I'll be right back. Bill |
| It looks like all you need to do is sign up on that site and you will be able to read the link. |
| Sled, Try reading this quote I got from KTMtalk: "Valve adjustment KTM RFS (or ANY 4 cycle) engine Top Dead Center: Commonly referred to, as TDC is the point where the piston is up. Power stroke: On a 4 cycle the engine produces power every other time the piston is up, while the piston and crank are in the same position (TDC) every turn the cam turns of crank speed so the cam is in its position to adjust, both cam lobes facing down every other turn! Thus you cannot just put the piston at TDC and adjust, the odds are 50/50 that the cam is in the right spot. Overlap stroke: The other turn where the piston reaches TDC is called the overlap stoke, the valves are each open very slightly, approximately 1mm with the exhaust closing and the intake opening. Not the place to adjust the valves! Clearance: To allow the valve to fully seat and transfer the heat it accumulated when open, and to allow for heat expansion when hot, the camshafts lifting pattern and valve train are designed to operate with clearance lash or gap between the valve train and the valve. Too much clearance and the cam and cam followers are prone to wear out. Too little clearance and it can burn a valve, or if you are luck, just not start at all so get it right. KTM has a service bulletin recommending that we ignore the prior specs and set the valves at .12mm which in inches translates pretty closely to .005. Rotation: Note that the engine rotates the same direction as the wheels and that when we rotate the engine we are fighting the valve springs, the easiest way is to put the transmission in top gear, this gives the wheel max leverage against the engine, conversely to how 1st gear gives the engine max leverage against the wheel. Then we rotate the engine by the rear tire. If you want to avoid pulling the spark plug out you can, just hold the manual compression release while turning the engine. Getting to it: First remove the seat & tank, from there I have done it radiators on, and hated every minute of it, I have done radiators off, it is more labor but maybe less maddening? (On '03 try setting the radiators aside without disconnecting the hoses) Unless the bike is spotless I like to take a can of Brake Clean and someone elses toothbrush, spray & scrub the valve covers and the area around it, then spray the area around the spark plug with the brake clean to flush out that area. If you have compressed air a good blast would help clean debris out of this area but watch you eyes! Then remove the valve covers and if you are going to the spark plug but if you do it my way there is no need on the plug. Now we must locate the heal of the cam where the valve lash is to be adjusted. Common way: The common way it to find TDC on the Firing stroke. The problem with this is too many folks end up on the Overlap stroke. This causes endless confusion, people putting straws down plug holes and endless other tricks that still often leave them on the wrong TDC. My way: With this method you do not need to remove the spark plug, magneto cover, skid plate or the TDC bolt in the bottom of the crankcase or the associated dirt. Intake valves; Transmission in top gear, rear wheel off the ground, if you have a helper one can watch the valves and hold the manual compression release while the other rotates the engine with the rear wheel. Rotate the engine gently with the wheel to locate the point where the exhaust valve starts to open then rotate very gently until the exhaust valves are 1/2 way open! Minor frustration, we are now fighting against the valve spring which wants to roll the engine back, so to stop it you either have to have a helper hold the rear brake or, as this gets pretty boring so; Option 1; Take a tie down, hook one end to the brake pedal, wrap in under the bike and up the left side to something like the top of the frame behind the engine. Now just tighten the strap so the brake can keep the engine from rolling back. Option 2; Put a bar thru the spoke of the rear wheel adjacent to the swing arm to stop the wheel. At this point the Intakes are on Center of the Heal of the Cam. Proceed to adjust. Exhaust valves; As above, except, locate the point where the intake valves have opened and are 1/2 way closed (engine rotating forward). As the intake is closing the engine will want roll forward PAST the way point and the lash in the transmission and chain will make it so you can not stop the engine, so let it go just past, then roll the wheel backwards and secure it with the brake or bar again. Now proceed to adjust the Exhausts. ALWAYS! ALL 4 STROKE ENGINES: With the engine rotating its correct direction the exhaust is adjusted when the intake is closing and the intake is adjusted when the exhaust is opening! Adjustment: If you are a feeler gauge kinda guy; As the clearance is so small and you can not get a straight approach with the feeler gauge dont be surprised if you can not get it in. I like to loosen the jam nut (10mm box wrench) and loosen the (one at a time) adjuster a couple of turns, slip the gauge in, turn the adjuster down lightly against it, then tighten the jamb nut. In doing so often the adjuster will creep tighter slightly and cause the clearance to close up. What you need to do as you tighten the jamb nut is do kind of an isometric exercise where you are holding the adjuster against rotation with equal and opposite force of the rotation of the jamb nut! This may take several practice attempts. As soon as you have tightened the jamb nut, do not pull the feeler gauge out, just try to slide it around in the gap! When you have it right it should slide with some, but minimal drag or resistance, no drag and it is too loose, heavy drag and it is too tight, may even be holding the valve open? Take a little time, you will have to redo a few times at first but once you pull the gauge out you may not be able to get it back in so get it right first! Oh, and by the way, the jamb nuts need to be tight! If you are a 1/6th turn kinda guy; I think it was the Husaberg guys that came up with the theory that fraction of a turn will do! The Bergs have a different thread pitch, I think they use 1/5th of a turn? My first reaction was that is crude, then I tried it a few times, now do it every time. That is based on a turn equates to .75mm (on the KTM tread) and.75 div by 6 = .125mm and .12mm is spec so for all practical purposes 1/6 turn is right on! Loosen the jam nut (10mm box wrench) and very lightly tighten (one at a time) the adjuster till it contacts the valve, note where the screw slot is aimed, turn the jamb nut to a corner of the hex aliens with the slot, make a small scratch in the cover gasket surface in line with the next hex point left (hex being 1/6th turn to the next point). Then turn the slot to that point, then tighten the jamb nut. In doing so often the adjuster will creep tighter slightly and cause the adjuster to tighten up. What you need to do as you tighten the jamb nut is do kind of an isometric exercise where you are holding the adjuster against rotation with equal and opposite force of the rotation of the jamb nut! This may take several practice attempts. As soon as you have tightened the jamb nut just double check that it did not creep, the slot aimed at the mark we made 1/6 turn left of contact and move on the next valve. The jamb nuts need to be tight and there are a couple of ways to deal with it; 1: Get out the torque wrench, check the factory spec and torque it down. Problem is with that is your locked into using a socket so you wont have the screw driver resisting movement of the adjuster, if the torque was close it should be OK. If it turned the nut much it may creep the adjuster around and changed your clearance setting. Thus what you have to do is be very close by hand before putting the torque wrench on it. 2: Perfect way, fabricate a crows foot type box wrench so you can use the torque wrench and the screwdriver simultaneously. In doing so there is a leverage factor that needs to be computed to arrive at a different (lower) torque spec and you probably need four hands to do it. 3: My way again. Put a nut and bolt together in a vice and torque to the spec, put the undoubtedly shorter box wrench on it to get a feel for how tight that is. Repeat a few times and feel how tight that torque feels. Then set the torque wrench aside and do it by hand. Now that we are done lets just double check our work, remove the bar from the rear wheel and rotate the engine forward to the checking points, hold it there with the rear brake momentarily and confirm a small amount of lash. Re-assemble dont forget, add coolant, return the toothbrush to its owner, go ride." Also, here is a photo equipped link: [Only registered and activated users can see links. ] With appologies to KTMtalk for pirating this info. Bill Last edited by Florida 393; 05-06-2006 at 10:04 PM. |
| Thanks everyone for all of the help. I will try it later tomorrow after I ride. |
| Valve adjustment on the YFZ 450?? | 2fun | ATV/UTV - Yamaha | 19 | 02-13-2009 09:31 AM |
| Valve Adjustment! | YFZKID | ATV/UTV - Yamaha | 5 | 04-19-2008 11:17 AM |
| Valve adjustment & other ?'s | TRXman86 | ATV/UTV - Honda | 13 | 10-17-2004 11:42 PM |
| valve adjustment? | Riley_400 | 4-Stroke Motorcycles - KTM | 11 | 03-23-2004 09:23 AM |
| valve adjustment | INsANE_MOTO | 4-Stroke Motorcycles - General Discussion | 11 | 02-15-2004 06:18 PM |
