YZ450 neutral switch and hard startingThis is a discussion on YZ450 neutral switch and hard starting within the 4-Stroke Dirt Bike - Yamaha forum, part of the 4-Stroke Dirt Bike Bike Forums category; I have grafted a YZ450F motor into a TZ250 GP bike chassis.
One of the problems with this was the ... |
| I have grafted a YZ450F motor into a TZ250 GP bike chassis. One of the problems with this was the fact that the kick start could not be fitted because of the frame position. This did not seem like a big problem because I thought I could bump start the bike. Starting the bike proved to be much harder than I thought, we must have pushed the bike up and down my street 50 times and only managed to get it started once. When it did start the motor seemed to heat up very quickly, this worried me so I talked to Yamaha about this and was told that it was normal, and that the headers would glow red hot if the bike was left idling. This got me thinking. Perhaps Yamaha retard the ignition so that it fires after top dead centre when the bike is in neutral. To test this I cut the neutral wire and connected it to a switch, this switch allows me to tell the CDI that it is in neutral while I try to bump start it. With the switch on the bike fired up without a problem. The reason I have posted this message is to make all you YZ/WR450 riders aware of a potential problem. If you stall the bike and try and kick start it while still in gear you could damage the engine cases, this is because you run the risk of the motor kicking back while the kick start is engaged. This kick back is caused because the ignition is firing before TDC and may force the motor to rotate backwards. If the kick back is hard enough it can break the engine case around the kick start. A good idea would be to tee a wire into the neutral switch wire, then take the second wire to a handle bar kill switch. This would allow you to kick it while in gear as long as you hold the button in. |
| Take it off entirely wmc, Most of the 450 and 426 riders took the neutral switch off and put a cover over the opening (I used a ZipTy cover.) The switch is to keep the revs down in neutral by cahnging the ignition mapping, as the European standard mandates the sound testing be done. Check the archives here and at Thumper talk for some of the posts on this. Some do feel taht they get easier starting with the removal of the switch. Satch had the best idea on his old 426 when he goe the cover with a site glass for oil level. Taht must be some creation you have. Enjoy the road rashing with that bike. I remember working on TD and TZ 250 Yamahas back in the mid 70's. Great bikes thast were giant killers for a while. Regards, Bill |
| I think you will find that the neutral switch will make the bike much easier to start. This can easily be tested by grounding the wire and trying to kick the bike in a lazy fashion. I think you will find that it still starts easily. Then disconnect the wire and try the same lazy kick. The bike will punish you for the lazy kick. We found the bike almost impossible to start without the neutral switch grounded (simulates neutral position when grounded). That was with two people pushing on a down hill. With the switch grounded the bike was easy to start, even with one person on the flat. The gearing on the bike is 16/36 so even a bump start in first gear does not turn the motor over very fast. I will put a timing light on and see exactly what the ignition advance is with the switch on and off. |
| Actually the "blue wire mod" was recommended "back in the day" on the 426 to IMPROVE starting. The blue wire when disconnected, bypassed the nuetral safety switch. As Florida393 mentioned, alot of us removed the switch and wiring all together with ZERO starting issues. Also, the factory bikes do not run a NS switch either. I think there maybe something else going on with the wiring on your bike. |
| When you say "bypassed the neutral safety" do you mean the protection from over rev in neutral? |
| I mean removed, no longer there.. not working |
| I was asking what you meant by safety not bypass. Did the "rev limit in neutral" info come from Yamaha or was it something that was noticed by riders. The reason I ask is because I think it is far more likely that the limit is a side effect of the ignition retard rather than the goal. Retarding ignition in neutral to aid starting is a logical thing to do. How many people would rev the bike past 7000 in neutral? I doubt that it would be enough to make Yamaha spend money and development time to add a neutral rev limiter. Revving the nuts off it in first gear waiting for the gate to go down is going to be every bit as bad as revving it in neutral, and more likely to happen. These points should be enough to show that the limit in neutral is a side effect. That brings us back to the real reason for the neutral switch. To retard ignition to help make the bike easier to start. Why is everyone removing the switch? I don't see what is to be gained by removing the switch unless you need a sight glass for the wet sump kit. |
| Do you think the purpose of the neutral switch is as a rev limit in neutral? |
| I cannot get to the link you posted on the blue wire change, just times out |
| This mod was a factory race team idea wmc, The original modification came form the Yamaha MX, SX and off-road teams. As stated above, per Yamaha, the switch served the purpose of limiting the revs in neutral for European sound testing of consumer purchased bikes (EU requires the bike be in neutral for the test and they are dead serious about sound testing there). The switch was looked at as more weight and something else to short out there by the race teams so it was reomved. Ty Davis, a Yamaha off-road rider (I.S.D.E. tema member, WORCS, National Hare and Hound series and BITD series) has an accessory company that sells a cover. Several other manufacturers make covers of different designs. I removed mine in 2003. My '02 426 has started easily and with no kick back since the removal, including hot starts on the track. Bill |
| For what it's worth, our race bikes(8 YZF450&505s) have no neutral switch, no choke and no hot starts, no accel pumps(45 Mikunis). 3 kicks max any time to start...it's a wonder what spot on jetting gets you. We also have "starter nuts" on the end of the cranks of our Framers(2). Stick the remote starter in and hit the switch...voila! Tdub |
Similar Threads for: YZ450 neutral switch and hard starting | ||||
| hard starting | Michael Parker | 2-Stroke Dirt Bike - General Discussion | 20 | 01-17-2008 12:48 PM |
| neutral switch? | YZ125motoracer | 4-Stroke Dirt Bike - Yamaha | 8 | 09-06-2006 05:00 AM |
| Help, hard starting CR | CRs4life | 2-Stroke Dirt Bike - Honda | 26 | 02-16-2005 12:06 PM |
| ZipTy neutral switch cover plate | Florida 393 | 4-Stroke Dirt Bike - Yamaha | 26 | 02-02-2004 09:37 PM |
| Neutral switch cover / Site Glass | Satch0922 | 4-Stroke Dirt Bike - Yamaha | 16 | 08-17-2003 04:39 AM |
