Old 06-25-2007, 07:35 PM
Last Online: 07-24-2007 03:53 PM
Default YZ250F backfire
My cousins YZ250F backfires when it gets warmed up and on deceleration. It isn't just 1 or 2 backfires, but it will do it almost constantly until you get back on the gas or shut it off. As we ride in tight twisty trails, you would think this is very annoying. Help!!!
Old 06-25-2007, 08:20 PM
KKXR400R's Avatar
Last Online: 06-01-2017 08:53 AM
Default Re: YZ250F backfire
Could be few things but I would start looking at some of the basics. Backfiring is a clear sign of a lean condition on the bottom. Did you do any pipe or intake mods lately? I would look into a larger pilot jet and see if that helps. Good luck
-Kevin-
Old 06-25-2007, 11:16 PM
That carburetor has a few rear facing air passages. If you have crud or air cleaner oil in them you can get that same symptom. Anything clogging the fuel passages as well. It is a pretty complicated carburetor so have a full manual or diagram handy when you start disassembly.
Did it get harder to start too?
Old 06-27-2007, 09:02 AM
joe346CBMX's Avatar
Last Online: 08-23-2013 01:11 PM
pay $20 for an adjustable fuel screw and start there and adjust the idle up a little. Once it sounds good it should idle on it's own and you can blip the throttle and check the response from the stand to get close. then ride it and go from braking to accellerating a few times to be sure it's good.
Turn it in to make it leaner in hotter weather, out to make it richer for cooler weather. If that does not do it, I'd look at jetting which is more complicated and time consuming.
My experience has been that my 07 YZF450 varies noticeably if it's 65 or 90 degrees. A 1/4 turn of the fuel screw on the bottom of the carb makes a significant difference. Note the screw is recessed so the easiest way to get to it is losen the clamps on the carb and rotate it out so the bottom is facing you more.
zip ty racing Zip Ty Racing and many others have these fuel screws with knobs on the end. they are much more easy to adjust than the stock screw.
here is part of the info on the zip ty site
If you own one of the modern four-stokes with the Keihin FCR carb, then you know their off-idle acceleration is tempermental when ambient conditions like temperature, humidity, and altitude change. And, you know what a pain it is to adjust the stock mixture screw on the FCR carburetor. The solution is adjustment when conditions change, and the Zip-Ty Fuel Screw allows fast and easy adjustment. The new FMS01s are carved from 7075 T7 Aluminum for improved tensile strength and have a redesigned tip taper and seating shoulder to accomodate the newest (3rd generation) Keihins. They feature a knurled forend for easy grip, anodizing for longevity, and laser etching for adjustment accuracy. The Zip-Ty Racing screw allows you to fine tune your bike easily and quickly with just your fingers - trail or track side. Specific ZTR Screw available for both models of FCR carburetor.
good luck, joe
Old 06-27-2007, 03:26 PM
Yes
Old 06-27-2007, 03:27 PM
Ty for the help
I will tell him
Old 06-27-2007, 10:42 PM
If it got harder to start I am betting on something being plugged. The easily adjusted needle is a nice item to have, for sure. Most of the time when a good running bike begins to run poorly as this one is it isnt a matter of an adjustment changing. I think this carburetor needs to come apart.
Old 07-02-2007, 08:31 AM
DPW's Avatar
DPW DPW is offline
It would be a good idea to check the valves too.
Old 07-24-2007, 03:53 PM
It turned out he got water in his gas
Old 07-25-2007, 11:19 AM
basanch73's Avatar
Last Online: 07-26-2010 03:02 PM
I'd recommend Madman's decel popping advice. After my eng rebuild with added compression and performance, I had the same situation happen. I upped the pilot jet one size up, adjusted the fuel screw accordingly, switched to 100 octane gas and immediately noticed minimal popping thereafter.
Brian
Old 07-25-2007, 01:51 PM
Tdub's Avatar
Hotstart not adjusted properly??
Old 07-25-2007, 01:56 PM
Lol, he lives!!
easy to see lots of things can make something "pop".
Old 07-25-2007, 02:17 PM
2smokeyz's Avatar
Last Online: 09-09-2008 05:03 PM
My CRF150F is doing to same. Should i try the same thing because it pops constantly on deceleration. Another thing is that it idles high when it gets warm. What should I try?
Old 07-25-2007, 05:15 PM
spartanbiker_117's Avatar
Last Online: 10-17-2017 01:42 PM
2smokeyz:
You should adjust your idle speed to idle smoothly at operating (warm) temperature. It won't idle very well when you first start it, but that's why you ride it a bit to warm it up
Old 07-26-2007, 11:51 AM
2smokeyz's Avatar
Yeah, i forgot to say that it goes up and down when its hot. The idle will jump i will ride it around a little and then it will go down. It just goes up and down randomly.
Old 07-26-2007, 12:02 PM
The Baron's Avatar
Richen the pilot circuit.
Old 07-26-2007, 04:10 PM
Tdub's Avatar
HOTSTART!!
Old 07-26-2007, 04:12 PM
The Baron's Avatar
BOTH!
Old 08-19-2007, 05:36 PM
Last Online: 10-26-2009 07:05 PM
my klx 125 pops also on deacceleration and when it is hot it sometimes shoots out a little fire but it also has a performance pipe?
Similar Threads for: YZ250F backfire
raptor 660 backfire cshaw1989 ATV/UTV - Yamaha 0 04-13-2009 06:20 PM
1983 TT 600 backfire masteroak Vintage Riding 2 03-16-2009 12:31 PM
Backfire ! AltonJones ATV/UTV Forums 6 05-30-2008 04:25 PM
carb backfire fixitsteven 4-Stroke Dirt Bike Bike Forums 4 01-24-2004 01:24 PM
BACKFIRE!! Riley_400 General Discussion 6 12-09-2003 12:13 PM
