yz 426f bogThis is a discussion on yz 426f bog within the 4-Stroke Motorcycles - Yamaha forum, part of the 4-Stroke Motorcycle Forums category; I've seen a couple of posts where this is mentioned and I think I am experiencing this on mine. The ... |
| I've seen a couple of posts where this is mentioned and I think I am experiencing this on mine. The bottom end of the throttle doesn't roll up very smoothly, leaving a dead power spot. By the time you get the motor to respond, there is too much power. Kind of spazzy. |
| The float needle sounds to be worn or pitted. Maybe just some crud in it holding it open a bit. Pull the carburetor and clean each jet individually then set the float level per the Faded thread in the Knowledge base forums. The FCR carbs are really sensitive to dust and grit in the jetting circuits. The whistling noise may well be an air leak. The intake boots, front and rear of the carburetor and suspect and prone to cracking from age and drying out. Also there is a nitrile o-ring between the intake bell and the carburetor body that can crack or break or get sucked out of the grooves it sits in. If you have an air leak you will get an extreme lean condition though. This I have had t deal with and it was the nitrile o-ring at the intake bell. For the bog I'd let G-Argyle put in his wisdom on the mod he perfected on the accelerator pump circuits or do the BK/GB accelerator pump timing modification. Bill |
| My 2002 YZ 426F??? | Sanchez #22 | 4-Stroke Motorcycles - Yamaha | 2 | 11-19-2007 09:10 PM |
| Looking for a YZ 400 or 426F motor/engine | 01426F | Wanted Items | 0 | 10-17-2007 10:30 AM |
| 01 YZ 426F PLEASE HELP | johnni | 4-Stroke Motorcycles - Yamaha | 4 | 01-20-2004 08:15 PM |
| 426F Air Filter ? | Dirtbikindad393 | 4-Stroke Motorcycles - Yamaha | 4 | 11-04-2003 08:50 AM |
| Coil on Cap mod 02 426F | Satch0922 | 4-Stroke Motorcycles - Yamaha | 1 | 10-03-2003 09:06 PM |
