valve adjustment?This is a discussion on valve adjustment? within the 4-Stroke Motorcycles - Yamaha forum, part of the 4-Stroke Motorcycle Forums category; i need some help and i knew that most of you guys could help..well can some one help me understand ... |
| i need some help and i knew that most of you guys could help..well can some one help me understand what really is a valve adjustment and how this effects your bike, how often or when to do it maybe even how to do the adjustment lol but yeah all of it all that good stuff regarding valve adjustments..im thinking i should do that on my 2001 yz426 thanks guys |
| Valves are what opens and shuts to allow gas to enter, and exhaust to escape. If they are out of spec, gas or exhaust (usually both) won't be able to enter/exit as well as it should. So in short, you lose power if they are out of spec. If they are far enough out of spec you'll have trouble starting, idling, and sometimes even running the bike. Checking to make sure they are in spec is a snap. Once you've done it, you'll wonder why you waited so long... If you do have to shim (adjust) your valves, it's pretty easy too, but I'd start with checking them, then we can cover adjusting them (actually, if you don't have a service manual (shop manual) I'd suggest getting one. Good luck |
-Kevin- |
| You really do need a manual. eBay Motors: Yamaha YZ426F Service Manual Download 2001 (item 250230083789 end time Apr-02-08 17:50:52 PDT) I can and will help where you have questions though. You can also watch the yz250f video to get a good idea of how it works. Excellent Video about Checking and Adjusting Valves If you have your owners manual it will at least tell you what the clearance should be. Otherwise, I'm sure another 426 owner can shed some light. |
| If you want the Clymer manual. The ATM store now carries them and I checked and we have yours in stock for $26 plus shipping. PM me if you want one. Trust me it makes adjusting your valves pretty painless. You may want a shim kit too, which you can also get for $69 plus shipping from the ATM store. Or I have a used shim kit that I used once when I had my 450 and I'd be glad to sell that to you for $30 plus shipping. I think I only used 2 or 3 shims out of it. Good Luck!! |
| Nah, it's pretty easy. Just remember 1 step at a time. First you need to check them. That's easy. Chances are you won't even need to adjust them. But you won't know until you check. |
| seriously guys i want to do it myself so i can also learn but i dont want to do anything that might mess it up even more i was counting on my pops on helping me out but it didnt turn out like that lol so i called the shop and they said they can do it for $120..what do you guys think |
| $120 What if they are still in spec? Less? I should be, because checking and adjusting are not the same and one requires more time. It's your money. I think you can do it. I can check my valves in 30 minutes. First time it took an hour. Adjusting adds another hour for your first try, 30 minutes for you second. I would see if they will at least just check for a lower cost. If they need adjusting, another cost. Like I said, I think you can do it, but it's your money. |
| Another thought... you check them, and if they are in spec, you save some $$ If they are out of spec, put the valve cover back on and take it to them to adjust. It might save you some $$ if you already have the shouds/gas tank/seat off the bike. |
well they said to adjust them thats what the price was gonna be..yeah im currently in medical school and i guess you can say im in a budget lol..can you help me check them like how you said and tell me how i would know if they are gonna need to get adjusted? |
| You got the owners manual correct? The information should be in it. You'll have to read it and see what part is specific to just checking your valve clearance. All you do is remove the gas tank, shrouds, & seat. Then pull the spark plug & wire, then remove the valve cover. Get your bike to TDC (top dead center) and check the clearance of the valves with a feeler gauge. If in spec, button it back up. If not.. we'll you can cross that bridge if you get to it. Is your bike not starting well, or idling well? |
i put in a new spark plug i checked the oil its clean i checked the air filter its clean i havent checked the carburator yet...they bike was running fine when i first got it but now its harder to start now im doing the right procedure to turn on and it wants to start but nope and when i did have it on i remember i would hear like a clacking noise and yeah the bike would stall on me too after awhile so i thought those would symptoms of getting my valves checked |
| Yep, that's where I'd start -- valves. It really is an easy job, but you'll have to let your $$ decide. |
| i would deffinetly want to save some money if possible lol summer is on the way and i deff want to ride..if you can take a look a that link and see what you can get out of it that might be useful to my situation |
#18
| you want 3-18.bmp through 3-19.bmp to check it. You use 3-18.bmp through 3-22.bmp to adjust it. 3.23.bmp has your valve clearance. Intake: .10mm - .15mm Exhaust: .20mm - .25mm |
#19
| so are the shims what adjust the valves? ive been going over some of the steps and i basicly have to make sure its at tdc and everything aligned and just check the valve exhaust and intake clearances and the shims right..i am having trouble with the formula that they give in the forums tho.. |
#20
| Yes the shims are what adjusts the clearance. So if your clearance is too tight, you want a smaller shim so it makes the size of the gap bigger. you are simply measuring the distance between the cam and the top of the valve bucket. When you check it, you can't even see the shims due to the bucket being over the top of them. |
| Valve adjustment on the YFZ 450?? | 2fun | ATV/UTV - Yamaha | 19 | 02-13-2009 09:31 AM |
| Valve Adjustment! | YFZKID | ATV/UTV - Yamaha | 5 | 04-19-2008 11:17 AM |
| 525 exc valve adjustment | sledhedz900iq | 4-Stroke Motorcycles - KTM | 13 | 05-06-2006 11:40 PM |
| Valve adjustment & other ?'s | TRXman86 | ATV/UTV - Honda | 13 | 10-17-2004 11:42 PM |
| valve adjustment | INsANE_MOTO | 4-Stroke Motorcycles - General Discussion | 11 | 02-15-2004 06:18 PM |
