Quantcast ttr125 choke stuck
All Things Moto! Online Community Rider Down Foundation
Go Back   All Things Moto! Online Community > Dirt Bike - ATV - Suspension Forums > 4-Stroke Motorcycle Forums > 4-Stroke Motorcycles - Yamaha
ttr125 choke stuck
This is a discussion on ttr125 choke stuck within the 4-Stroke Motorcycles - Yamaha forum, part of the 4-Stroke Motorcycle Forums category; Hey guys, I know it's been a while since I've posted up, been crazy at work. Well I finally made ...
Old 08-31-2008, 12:35 PM
Last Online: Yesterday 09:18 PM
Default ttr125 choke stuck
Hey guys, I know it's been a while since I've posted up, been crazy at work. Well I finally made it home with a little time left over to ride, only to find that the choke on my little trail bike is stuck, I have tried to remove the cable to lube it up thinking that the cable is stuck only to find that the plunger that goes into top of the carb is stuck and will not come out. Any suggestions? I have loosened the cable termination at carb. and soaked it down with wd40 with no luck. These things are almost impossible to start without choke.
Old 09-25-2008, 11:45 PM
AbsoluteZero's Avatar
Last Online: 09-25-2008 11:45 PM
If it hasn't been solved by now...
Use liquid wrench penetrating oil. soak that in there and it should come out as if never stuck. Really awesome stuff
Old 09-26-2008, 02:17 AM
Freak's Avatar
Hook 'Em
Last Online: Today 12:42 AM
That choke is above the clamps middle of the bars right? If you can't get a cable luber on it, might have to replace it.
Old 09-26-2008, 06:53 AM
krut2's Avatar
Last Online: Today 06:46 PM
that seems to happen on all of them....my friend has one and that happened.....we did all of that also with the soaking....but none of it worked so we just pulled up on it as hard as we could and it came unstuck....it was weird because he has never ridden it in the rain and its always been inside....but i dont recommend doing it because i have no idea about your situation....it worked for us but i have a feeling we were just lucky....
Old 09-26-2008, 08:23 AM
krzywhiteboy's Avatar
Wheelie Master
Last Online: Today 01:46 PM
Those carbs just plain blow. On my wifes I changed the carb over to one for a YZ85. It made such a difference. It even made it so that you only had to warm the tiny beast up for 2 min instead of 5 before riding it.
Old 09-26-2008, 09:02 AM
krut2's Avatar
hahahahha yea....my firend was yelling at his for 20 minutes because it wouldnt start....and the fact that he wont trust me when i said that the bikes are jetted waaaaaayyy to lean from the factory and thats why it takes him 20 minutes to start it...lol
Old 09-26-2008, 09:55 AM
Freak's Avatar
Hook 'Em
I doubt it's lean. Maybe too rich.
Old 09-26-2008, 03:31 PM
krut2's Avatar
i doubt it.....the bike runs good when its warm....and it doesnt smoke the littlest bit....and his plug looked good(not black or anything)...
Old 10-18-2008, 05:46 PM
I appreciate all the suggestions guys, I finally made it back home yesterday, and took the carb off to see what was up. I had to take a pair of pliers under the choke body after unscrewing it, and pry it out. There was some kind of white crystalized crap all in the top of the needle assembly. No idea what it was or where it came from, only thing I can figure is some kind of corrosion? Once I got it out took everything apart and cleaned it as good as possible with B-12, put it all back togeather, and what do you know the bike started right up with no problem ( without the choke ), the only problem was that the bike wouldn't idle down, let it warm up completly and backed off the idle screw 1 1/2 turns. The bike now idles fine, just a little faster than it did before. Anybody got any idea what the white junk was? Or what would cause the idle to go crazy? Sorry so long winded, and thanks again for the help.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads for: ttr125 choke stuck
PJ Choke Jethro General Discussion 3 02-16-2008 07:06 PM
Need some help with using the choke mbogosia 2-Stroke Motorcycles - Yamaha 2 09-11-2007 06:56 PM
Choke won't stay on sircrashalot 2-Stroke Motorcycles - Kawasaki 3 12-31-2006 10:13 AM
Broke the choke... monoshock 2-Stroke Motorcycles - Honda 4 01-30-2004 11:49 PM
choke pillowgod ATV/UTV - Yamaha 2 07-17-2003 11:58 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright ©2002-2008, All Things Moto! Inc. All Right Reserved.
Page generated in 0.18120 seconds with 12 queries
