All Things Moto! Web Forums
TTR-125 won't idle!!
This is a discussion on TTR-125 won't idle!! within the 4-Stroke Motorcycles - Yamaha forum, part of the 4-Stroke Motorcycle Forums category; Put an FMF powercore IV pipe on my little bro's TTR125. Installed a 110 main and 17.5 pilot jets. The ...
Old 05-04-2004, 09:03 PM
Last Online: 10-10-2007 04:48 PM
Default TTR-125 won't idle!!
Put an FMF powercore IV pipe on my little bro's TTR125. Installed a 110 main and 17.5 pilot jets. The bike will only idle (SLOWLY) with the choke on, and dies when the choke it taken off. Yes, I warm it up completely before I take the choke off and the RPMs still drop off until the engine dies. Ive adjusted the air screw etc all friggin day and it still doesn't idle without the choke on. What's wrong with this damn thing? Thanks,
Jake
Old 05-07-2004, 11:04 PM
mxchic's Avatar
Last Online: 03-21-2005 08:50 AM
Default Re: TTR-125 won't idle!!
When the choke is on the bike is running richer. If it only wants to idle with the choke on the bike may be running too lean on the pilot. What is the stock pilot jet? You can call FMF and see what their jetting recomendations are for this exhaust system. You can also check the carb to make sure their is no sedement clogging up any of the jets. Spray it down with some carb cleaner just to ensure it clean. Check your idle screw and make sure it is not turned too low. You said you adjusted the air screw. Also make sure exhaust and air boot into the carb is secure and there are no leaks. My suspision is that the bike is just running too lean.
Old 05-22-2004, 12:46 AM
Dirtbikindad393's Avatar
Your ATM Amsoil Dealer
Last Online: 10-14-2009 10:24 PM
MXchic is right. If you have a pipe on it I would suggest doing the air box mod to start with. As far as it idling check the fuel screw and make sure its not closed up all the way. If its fine I would check the jets and make sure the pj isn't clogged. Try a 20 pj and see if that helps. What elevation are you at? What are the temps?
Similar Threads for: TTR-125 won't idle!!
98, Cr 250 idle, HELP!!! 80stars 2-Stroke Motorcycles - Honda 17 06-26-2007 08:16 PM
JR 50 Idle tjtibb 2-Stroke Motorcycles - Suzuki 1 12-01-2006 08:39 PM
125 idle WhiskeyThrottle 2-Stroke Motorcycles - General Discussion 7 09-21-2004 11:53 PM
idle p8nt 2-Stroke Motorcycles - General Discussion 4 05-15-2004 08:01 PM
Won't Idle Keetoman393 4-Stroke Motorcycles - Honda 2 12-28-2002 10:36 PM
