| Portal | Forums | ATM! Online Store | Photo Gallery | Moto Garage | RSS Feeds | ATM! Link Directory | Today's New Users |
TT 500This is a discussion on TT 500 within the 4-Stroke Motorcycles - Yamaha forum, part of the 4-Stroke Motorcycle Forums category; just replaced points... dealer said set to .016-.018, which I did, still a bear to start. Bike had been sitting ... |
| just replaced points... dealer said set to .016-.018, which I did, still a bear to start. Bike had been sitting for a few years till I got it 2 months ago. Did get it running when I brought it home, but not with out a lot of priming and back firing. Same deal now, any ideas??? Parts sure are pricey for this thing!! Almost $140 for a fuel petcock, set of points and a condenser? |
| What is the best way to set timing on this one? Any source on this site that will explain the process? |
| First, if you are going to keep the bike and work on it yourself, I would suggest a manual. [Only registered and activated users can see links. ] Second, there should be an access point on the flywheel (left) side of the bike. Once opened there should be a "T" and "I" mark on the flywheel. I haven’t work on a TT but this is very common. Once you align the "I" with the marker on the case, you should rotate the point plate to where the points, just begin to open. |
| Thanks, ordered one up yesterday. went and played with it some yesterday, it did start somewhat easily, idled fine, so I took a few laps around the yard with it. Can't wait to see how this beast will run once (if) I get it dialed in! |
| Your carb isn't the accelerator pump type it is a CV type. Hard starts will be common if you aren't spot on jetting and timing wise. Best of luck with the TT it is a sweet scoot. I have a VMX issue with the Hallman-Aberg 500 granf prix model in a full test. Bill |
| Welcome Big! I have an 83 TT600. First 4 stroke I have owned. Make sure you adjust your valves regularly and get the timing right. I have a cover on the left side of the engine where you will set the timing. Get a manual and it will tell you the correct specs for your year. What year is it? I gotta tell ya the TT600 is a beast and until I learned how to kick it it was difficult. When I cold start it, I have to kick it gently about 5-10 times and only let the kick lever come up to a point where I hear a distinct click. If I do this and then give it a good kick, it starts right away. Once warm it starts right up. Have fun and let me know how its going. |
| Mine is an '80. Got the manual yesterday and will try to check / adjust the valves next. compression release was a bit loose, so i tightened that up today, backfires a bit more, but would not start! I can use a conventionial timing light on this correct? just have to have an auxialary battery on hand to power up, correct? |
| Dude, you're awesome !! Just went out and figured WTH can't hurt to try it that way. First kick, off she went !! |
| And be careful not to roll the throttle when you are kicking it or it will add to the flooding nightmare. Once you figure out what works, you will not have any problems. I think each bike is just a little different and you have to feel out what works for yours. How bout a pic? |
| I'll see if I can get a few pics this weekend ! |
| Pics... finally! |
Here's how to post pics (from the FAQ): All Things Moto! Forums - FAQ |
