For those with yz250f..i need helpThis is a discussion on For those with yz250f..i need help within the 4-Stroke Motorcycles - Yamaha forum, part of the 4-Stroke Motorcycle Forums category; So i have about had it with this bike..09yz250f
my question to you guys is...at idle in neutral, can you ... |
| So i have about had it with this bike..09yz250f my question to you guys is...at idle in neutral, can you rip the throttle hard and it revs....mine dies. I have called yamaha, they cant do nothing, the shop i took it to said its fine and the valves are fine, i dont even think they looked at the carb, but i know something is wrong. You have to very slowly roll into it to get it to rev up. also its a pain in the *** to start.. with the choke out it starts, once you push it back in the bike cant keep an idle and dies, then it wont start and i have to pop start it to get it going again. Every shop says its operator error and i cant beleive yamaha is doing nothing for me and i cant stand this anymore. Im almost to the point of losing my cool. If there is anyone one these forums in south jersey that could take a look at this bike, i would really appreciate it. i'll pay u for your time cuz im done with these B\S shops...No shop seems to be honest anymore. Last edited by farrside420; 07-30-2009 at 09:32 PM. |
| Okay, let's start with the idle adjustment. There is a big black round knob on the side of the carby, start the bike and wind it in clockwise, you should hear the rev's increase as you do it. Get it to a point where it idles a bit fast but not overdone. Report back when you have got it, or not. |
| Definately check your idle, mine does the same thing. Didn't fix the bog but starts first kick every time. |
| Yep, it was the idle...Bumped it up a little bit more, no more bog, throttle response is much better.. Thanks again.. |
| you can adjust the fuel screw on the bottom of the carb also. in is leaner out is richer |
| Also - look into your leak jet. This meters the accelerator pump discharge and for a 4-stroke, it has a huge impact on engine acceleration. The leak jet is inside the carb. If you are lucky, you have a local shop that can make a good suggestion on the right size jet for your area - if not, call around. The leak jet has a tremendous impact. Look into it. Scott |
| Help with my YZ250F | MXMark | 4-Stroke Motorcycles - Yamaha | 12 | 07-10-2008 11:52 PM |
| Help! I've been had! 02 YZ250F | blueyami757 | 4-Stroke Motorcycles - Yamaha | 13 | 05-21-2008 09:16 AM |
| NEED HELP WITH 01' YZ250F | camaro80r | 4-Stroke Motorcycles - Yamaha | 2 | 09-14-2006 09:12 PM |
| YZ250F 03-04 DR.D Exhaust for 2005 YZ250F | zeka1 | 4-Stroke Motorcycles - Yamaha | 4 | 02-16-2005 08:20 PM |
| 01 vs. 02 vs. 03 YZ250F | YZ250F_Racer | 4-Stroke Motorcycles - Yamaha | 6 | 12-07-2003 11:54 AM |
