Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > 4-Stroke Dirt Bike Bike Forums > 4-Stroke Dirt Bike - Yamaha
TDC of compression stroke or exhaust stroke
This is a discussion on TDC of compression stroke or exhaust stroke within the 4-Stroke Dirt Bike - Yamaha forum, part of the 4-Stroke Dirt Bike Bike Forums category; How do you find out if the piston is at TDC of the compression stroke or the exhause stroke. The ...
Old 02-10-2010, 06:19 PM
Goobz_MX718's Avatar
Last Online: 10-27-2011 07:57 PM
Default TDC of compression stroke or exhaust stroke
How do you find out if the piston is at TDC of the compression stroke or the exhause stroke. The cams jumped teeth on the timing chain so the cams are not a reliable resource to figuring this out. No matter which stroke i'm on, neither of the two cams marks line up where they are supposed to. I'm replacing the chain and tensioner on my 2006 YZ450F. Believe it or not, the valves were not harmed during this mishap. Head and cyclinder was removed and put back together.
The cams are removed and the engine has been cycled over to find TDC. Having a hard time understanding what triggers the spark plug to fire. Thought i could figure this out by looking at the stator, but it's part of the crank so it spins 1:1 with the piston. I guess it's the CDI. How can i figure this out.
Please help
Old 02-11-2010, 07:17 AM
Please help
After giving this some thought maybe i have a better question. Does the spark plug fire on every stroke and the only thing constituting it being a compression stroke is the cams. In this case, it wouldn't matter if i was TDC on the compression stroke or exhause stroke as long as i was at TDC. Someone please correct me?
Old 02-11-2010, 08:10 PM
Crogg's Avatar
Last Online: 05-18-2013 06:34 PM
That is correct! You can line up the timing marks on the mag or unscrew the sparkplug and put a long screw driver down the hole...as you turn the motor over you can see top dead center and time the cams to that!
Similar Threads for: TDC of compression stroke or exhaust stroke
form on 2 stroke vs 4 stroke trail bike mxmama393 Dirt Bike Riding Tips 39 03-20-2010 11:44 AM
4 stroke compression reading dafro42 4-Stroke Dirt Bike - General Discussion 1 08-19-2005 08:46 PM
Compression Stroke Help Old Man ATV/UTV - Yamaha 14 02-08-2005 02:40 PM
4-stroke exhaust? mxracer89 4-Stroke Dirt Bike - Honda 2 03-28-2004 02:44 PM
How To Check Compression In a Two Stroke? 2kHondaCR500R 2-Stroke Dirt Bike - Honda 4 03-26-2004 06:56 AM
