Sticky ClutchThis is a discussion on Sticky Clutch within the 4-Stroke Motorcycles - Yamaha forum, part of the 4-Stroke Motorcycle Forums category; Hey guys how's it going? I'm new to ATM and so far liking what I'm seeing... Anyways, I have a ... |
| Hey guys how's it going? I'm new to ATM and so far liking what I'm seeing... Anyways, I have a question about my 03 yz450f. The clutch seems to be sticky when it's cold. After running it for a few mins and it's warm with oil flowing through the engine it frees up. Anyone else ever had this happen or know anything about it. Thanks : |
| All I can say is check your clutch basket,if it is even very slightly worn then it will stick some.Maybe poor oil flow? |
| had the clutch basket out and checked it myself as well by a mechanic. It looks perfectly fine. I was thinking about drilling the oil ports out to 4mm from 3mm. Last edited by JeFF 03yz450f; 10-23-2008 at 03:48 PM. |
| is it hot or cold where you are located?Try using a thinner oil before you go changing aything.Make sure your coolant is good and topped off all the time when riding with thinner oil because it will heat up more and faster,sounds like what your problem is. |
| Welcome to ATM by the way Jeff!!!! Cody is getting down the right road. What oil are you using? Exact brand and weight. What climate are you in? Does Ontario = Ontario, Canada? Huge factors in how things work in the clutch dept. |
| I love amsoil,I use it in my 125 and my sx-f |
| Forgot,also make sure the oil is circulating when the bike starts. |
| Hey guys, yeah it's ontario, canada and I was told to use 10w-30 motul which I use in my street bike as well... A mechanic told me to do so and I went with what he said for the convenience. That was my next thought to go to a lighter oil.... Yes, I warm up the bike completely to ride and the clutch will work good, but I was referring to when it sits in the garage and is cold... with my street bike I can have it in first and pull in the clutch you can free wheel the bike with ease. With the 450 it's hard to move and second gear is a little easier... neutral it's perfect with no unusual stuff. I have flipped the clutch plates as well and inspected all parts. I'll fluids are set to factory. By the way it's starting to get cold here... LOL |
I would love to see pictures of the basket, close up pictures of the fingers on the basket. If you feel a slight hump or notch with your finger nail in the basket or inner hub it is poop. The second and more slight factor is the oil and its viscosity. It really needs to get warmed up more than you think in colder temps meaning below 50 f I think thats 10 c. Here is an article I wrote about changing the YZ450 clutch and the symptoms. Its full of pictures just click on the links. Hope that helps. Last edited by Dirtbikindad393; 10-24-2008 at 09:55 AM. |
| hey dirtbikindad, I found your clutch post just before you replied... very good article. I had it apart and never took any pics of it I'm an idiot. It definitly doesn't look as bad as yours did. Did I mention before that two different mechanics looked at the baskets and plates and said they were good, but how much roughly did you spend to upgrade everything. I would be interested in doing this over the winter for sure and I'm most likely going to change to a lighter oil. Thanks again |
I truely don't think you need to go to a lighter oil. You might want to go to a better oil but 10W oil should be good with a good warm up. You have proved that in your street bike. I would however change to a heavier oil in the street bike for the summer. Better protection for the long rides and high heat in the engine. To read more go to the Amsoil Vendor thread here on ATM and read the motorcycle oil study. |
| These 450's are Soooo hard on clutches,hope you find out whats wrong with it.A rlue of thumb:Cold weather=thin oil,warm weather=thick oil.Replacing clutch plates and springs is so easy that I do it every few months just to get max power to the ground,my basket in good shape,and that "new" feel.Good luck |
| you guys might want to sticky this | Macho393 | GMB Remembering Those Who Rode | 23 | 08-24-2006 07:14 AM |
| here is a sticky for us all | Macho393 | General Discussion | 3 | 05-28-2005 10:34 PM |
| Sticky Clutch | kxmatty | 2-Stroke Motorcycles - Kawasaki | 3 | 05-26-2005 07:00 AM |
| Why is my Clutch sticky? | Reuel | 2-Stroke Motorcycles - General Discussion | 3 | 04-04-2005 10:55 PM |
