Old 05-04-2017, 08:28 AM
Last Online: 05-10-2017 03:55 PM
Default remove yz426 2001
i believe i have dropped a cam bearing keeper into the bottom of the motor (can't find it)
so i need to remove what is left of the motor to shake it up a bit to try to avoid splitting the cases to be sure the keeper will cause no damage.
i cannot find a way to remove the rear mount bolt. it feels solid when i try to tap it either direction (both nuts are off)
is there a secret to it?
thanks
Old 05-04-2017, 09:10 AM
Last Online: Today 11:23 AM
It should be in the ignition cover area, have you tried removing the stator cover, stator and flywheel to see if you can find the keeper?
As for the bolt you are concerned with, exactly which bolt is it you can't remove? The swingarm pivot bolt should not have a nut on both sides.
Old 05-04-2017, 09:36 AM
X2 plus most likely it will be found stuck to the flywheel as it is magnetic.
Old 05-04-2017, 12:40 PM
Default stubborn
i have removed all i can remove, drained the oil and inspected with a borescope and searched with a flashlight and a magnet. (It looked like it was heading for the gearbox cavity when i saw it fall). i suppose it could be lost outside the engine - but since i am replacing everything above the crank, i hate to "suppose".
yes, the swingarm bolt - had a nut on one end - other end is some kind of flange. it does not want to come out.
Old 05-04-2017, 12:47 PM
If you had the head installed when you dropped the retainer, it shoudn't be able to make it into the gearbox.
Your swingarm pivot bolt has rusted due to lack of maintenance and is now stuck in place. You can try to spray some penetrating oil on it to see if it will loosen up, you're going to need a long punch of some sort and a pretty substantial hammer to try and drive it out.
Old 05-04-2017, 02:39 PM
Default keeper
head was installed, I was taking the cams out - beginning to rebuild the top end.
both keepers fell into the abyss. the front one stuck to the flywheel, rear was visible in the cam chain cavity for a bit - seemed to go inside the engine thru a small cavity on the bottom. I pulled off everything I could get off. swingarm bolt shows no sign of rust, but it could be rusted in the non visible center. it felt pretty solid when i punched it.
Old 05-09-2017, 01:42 AM
Law94's Avatar
Last Online: 04-29-2020 03:34 AM
Did you ever able to retrieve the cam bearing keeper?
Old 05-10-2017, 03:55 PM
Default grrr
nope - i have rigged a pulley system to hang the bike upside down to see if anything shows up. Nothing yet
Old 05-10-2017, 11:47 PM
Law94's Avatar
That sounds stuck in there pretty good.
Similar Threads for: remove yz426 2001
Hot start cable for 2001 yz426 Luckyduck272 4-Stroke Dirt Bikes - Yamaha 2 05-23-2011 08:29 PM
2001 yz426 carb problem (need help) bgdaddyn 4-Stroke Dirt Bikes - Yamaha 8 07-14-2009 02:35 PM
2001 - YZ426 Engine Miss peterbilt 4-Stroke Dirt Bikes - Yamaha 2 07-21-2004 04:31 PM
2001 YZ426 for sale TexasDirtNap393 Classified Ads 16 04-24-2004 05:59 PM
2001 YZ426 for sale Psycho 4-Stroke Dirt Bikes - Yamaha 6 09-10-2003 05:02 PM
