Old 06-29-2004, 10:27 AM
huffdaddy70's Avatar
Last Online: 02-28-2012 08:04 AM
Default Need help with linkage and steering stem
I figure my bike needs the linkage and the steering stem greased and lubed pretty bad. Can anyone tell me how hard it is to do and kind of give me a little step by step process on how to do it? Thanks for all the help!
Old 06-29-2004, 10:46 AM
drman's Avatar
Default Re: Need help with linkage and steering stem
It's easy. Take the front wheel off, forks out of the triple clamps, handlebars if needed--to reach the stem nut, pull the top triple clamp off, then loosen the spanner nut. If it's tight you'll need to get a punch and a hammer to loosen it. After you get the spanner nut off, the bottom triple clamp and stem will want to fall out, so hold it and then pull it out. Then clean your bearings if they need it and apply a pretty good sized amount of grease on them and stick them back in the tube.
Old 06-29-2004, 11:13 AM
Honda_Rider_XR's Avatar
Last Online: 04-19-2008 11:56 PM
For linkage, you're going to want a manual.. Because it involves taking the whole subframe off, the shock, swingarm, etc..
Grease those steering stem bearings with TONS of greese!
Old 06-29-2004, 08:21 PM
Thanks for the help guys!
Old 06-29-2004, 08:32 PM
drman's Avatar
Oh...sorry...I didn't see you also said linkage bearings. While you are in there go ahead and pull the swingarm off and grease those...that way you know that all of your bearings are good to go. You shouldn't really need a manual if you are mechanically capable.
Similar Threads for: Need help with linkage and steering stem
aftermarket steering stem ? Twiztid ATV/UTV - Yamaha 7 07-15-2006 06:47 PM
YFZ 450 steering stem ? smash metal ATV/UTV - Yamaha 35 04-13-2005 09:45 AM
Steering Stem reborn_450 General Discussion 9 12-08-2003 03:59 PM
Here's the story... steering stem Honda_Rider_XR General Discussion 11 09-24-2003 10:28 AM
Steering Stem Disassembly??? Ranger_450F General Discussion 11 08-14-2003 10:06 AM
