Need help Jetting with new pipe...This is a discussion on Need help Jetting with new pipe... within the 4-Stroke Motorcycles - Yamaha forum, part of the 4-Stroke Motorcycle Forums category; I will be getting back my new bike tommorrow and will be putting on the new White Brothers Carbon Pro ... |
| I will be getting back my new bike tommorrow and will be putting on the new White Brothers Carbon Pro pipe tommorrow night. I am just looking for tips on how to get started jetting it right. The bike has a 165 stock main jet, and it came with a 160 and a 170 spare jets. Should i go ahead and put the 170 in before i even crank the bike with the new pipe on it and start from there or what? I figured it will need to be richened up for sure is why i wondering about putting the bigger jet in right away. Thanks for any tips and any help! |
| Huff, If anything you may need 1 step larger on the main 168 but I would wait and see how it runs in stock trim first. One thing I would recommend Highly is buying the JD Jet kit and following his directions you won't be sorry. |
| should of bought a 2stoke, eaiser with jetting. just ride it and test different jets and see what runs better |
| huh? That's not true at all. 4 stroke is just as easy to jet, and in fact are less bothered by air temp changes and altitude then pingers. Anyway, moving right along... Have you broken the bike in yet? If not I would break it in before adding the pipe, just so you avoid jetting woah's during break in. Then yes, do as Ranger said. Didn't it come with any jetting recommendations? |
| Huff, I said it before and I'll say it again...You lucky bass. Get that can on and jetted and let's see some pictures. |
| Yeah Woody, the bike is broken in and no, it didnt come with any jetting specs ( which sux)! |
| Huff, It's hard to say what you need as far as jetting without some kind of symtom/ condition the bike shows. The 1 Size larger main is a generalization, it is recommended due to improved performance you add 1 size to the main. If I where in your shoes and I didn't want to fork out the bucks for the JD kit. I would throw the new Exhaust on and see where I was. Then as needed Fuel Screw: Starting, Pilot: Starting - 1/8 throttle, Clip Pos: 1/8 to 3/4 throttle, Main: 3/4 and up, |
| Thanks Ranger! Good info! |
| kx 250 jetting with fmf pipe??? | spinner | 2-Stroke Motorcycles - Kawasaki | 2 | 07-03-2009 07:17 PM |
| jetting for fmf pipe? | 86cr250r | 2-Stroke Motorcycles - Honda | 2 | 10-27-2008 10:14 AM |
| Jetting for a fmf pipe.... | 2001hondacr125 | General Discussion | 2 | 04-19-2008 04:38 PM |
| Pipe jetting q's. | kxmoto4life | 2-Stroke Motorcycles - General Discussion | 1 | 04-11-2008 06:37 PM |
| Jetting for a PC pipe | YZ125motoracer | 2-Stroke Motorcycles - Yamaha | 3 | 03-21-2006 04:30 AM |
