Kick Starting a YZ250FThis is a discussion on Kick Starting a YZ250F within the 4-Stroke Dirt Bike - Yamaha forum, part of the 4-Stroke Dirt Bike Bike Forums category; i have alot of trouble kickstarting my friends 2004 YZ250F he just got a 2 weeks ago he let me ... |
| i have alot of trouble kickstarting my friends 2004 YZ250F he just got a 2 weeks ago he let me borrow it and i can never start, and im buying the bike soon. is there anything i could put on it so its starts easier or is there a really big secret i know to use the compression thing and some other secrets but they dont work. i just wanted to know if there was something i could buy for my new bike too. |
| let it break in, its new, give it time. when my 03 was new it took awhile to start i bet. but i kick it once and its up and making alot of noise |
| I always pull the decomp handle in and as you start to kick down let the handle go and they start up almost immediately every time. Does your buddy have a hard time starting it too? |
| The 04 doesn't have a decomp lever on it, what you're pulling is the hot start. Leave the hot start alone (unless the motor is actually hot) and just kick it. Sometimes it's easier if you get the piston to TDC (where it's hardest to move) then give it a good kick. |
| fuel on, turn throttle to WOT 2 times, choke on, and kick, DO NOT TOUCH THROTTLE!!!!!!! Put right hand on the front master cylinder while kicking. I think the bike starts easier with 1/2 race gas and 1/2 pump gas too. |
| everybody has trouble starting the bike so its not only just me |
| my 03 yz250f was hard to start for the first 4 weeks that i had it and check the oil my bike is pocky if i put a little to much oil it wont start or it would be really hard to start |
| dude...what are yall talkin bout?! My 04 yz250f starts 1st kick every time... push the kickstarter til the engine catches, then pull up and kick HARD! give it NO GAS!:yum |
| my 03 start up 1st or 2nd every time now it just needs to get borken in |
| my new crf 100 starts up everytime. it takes about 1-2 kicks to do it tho. i never had to break it in to start it tho. maybe it is just the lack of finece` in your kick. i might be wrong tho. |
I have a bone stock 04 and never have a lick of trouble starting it. Just get the bike in neutral, dont touch the throttle, and kick. If the bike is cold turn the choke on. If the bike has just been ridden hard and then shut off for only a minute or so, pull the hot start while kicking. |
| The bit about give 2 twist of the throttle is to prime a dry engine and only applies to the first kick of the day. If it has been run at all that day, DO NOT twist the throttle. |
| i finally can get it start now on a few kicks, because i got my own to practice on |
| I have a 450F and during the summer i have to pull the hot start lever for it to crank even cold. But if i use the lever she'll fire up first kick. I give it two small blips of throttle then pull the hot start and kick it one time and she start purring! |
Similar Threads for: Kick Starting a YZ250F | ||||
| 2001 YZ250F HARD STARTING!!! HELP!! | camaro80r | 4-Stroke Dirt Bike - Yamaha | 11 | 10-09-2010 09:57 AM |
| 2000 cr250 kick start is starting to rub on frame | Kanookie | 2-Stroke Dirt Bike - Honda | 2 | 04-04-2008 07:59 AM |
| The end of kick starting and my sadness | daveythewavey19 | General Discussion | 3 | 03-13-2008 01:23 AM |
| CRF450 Kick Starting question | AndrewPA | 4-Stroke Dirt Bike - Honda | 2 | 04-18-2004 11:10 PM |
| Something strange in kick-starting | smithers | 4-Stroke Dirt Bike - Honda | 22 | 01-06-2004 11:06 AM |
