Old 10-29-2007, 03:48 PM
Last Online: 11-18-2007 06:01 AM
Default how to timing my 426
do some body can help me how is the timing position for the cams thanks
Old 10-30-2007, 09:39 AM
basanch73's Avatar
Last Online: 07-26-2010 03:02 PM
Default Re: how to timing my 426
I've posted pics and instruction on my cam chain replacement guide and tear down and rebuild posts in the general knowledge base forum. They should help. If that still doesn't help, there's the Yamaha Online Manual link in the same forum that will have how to do this listed in there. If all else fails, let me know and I'll PM you with help.
Later,
Old 11-02-2007, 09:41 PM
Last Online: 07-09-2020 11:18 AM
In a nutshell- remove the timing plugs (if you have oil in the bike, it will run out the larger plug). Remove the cam cover (requires removing seat and gas tank). Put your 14mm socket on the crank nut (visible through the large timing hole). When you can see the "I" shaped timing mark through the smaller timing plug hole, the cam lobes should be facing opposite eachother (exhaust cam towards front fender, intake cam towards air box) and their should be dots on the cam gears that are flush with the top of the head.
Similar Threads for: how to timing my 426
YFZ to YZ timing cam mod Dice Wiley ATV/UTV - Yamaha 18 07-06-2007 10:50 AM
yzf 400 cam timing glen 4-Stroke Dirt Bikes - Yamaha 2 06-11-2007 06:50 PM
Cam timing? Mopo 4-Stroke Dirt Bikes - Yamaha 27 06-11-2007 01:32 PM
Timing Tuktuk08 ATV/UTV - Kawasaki 3 08-27-2004 12:10 PM
timing? Racer#857 General Discussion 4 01-03-2004 10:11 PM
