Old 02-23-2013, 01:53 PM
Last Online: 02-23-2013 04:54 PM
Default Carb Issues.
Hey guys, i am currently having an issue getting my friends 2001 YZ250f to idle. It has the classic Keihin Flat CR carb but being an old thumper has 2 chokes. one for hot (lean choke) and one for cold (rich choke).
before tearing into the carb i did a compression & leakdown test and both passed very satisfactory. the issue we are having is the bike does not want to sit at an idle with out the chokes engaged. the second you disengage the chokes, it dies out.
before cleaning we noticed it had a 155 main jet and the needle set to 5th position. (standard is 175 main jet/ needle in 4th position) pilot jet is a #45 and pilot screw is 1 &3/4 turns out (referencing to the service manual).
i have swapped everything back to factory and i have currently boiled the carb body. any suggestions would be great. i have yet to put the carb back into the bike to try it out.
Old 02-24-2013, 03:00 AM
i guess my first suggestion is to put the carburetor back on and try it. i think you are using some sound logic to get the rig back to its original setup. set the float while you are at it, or you wont be back to factory specs yet.
Similar Threads for: Carb Issues.
TTR 90 carb issues paulpgh 4-Stroke Dirt Bikes - Yamaha 2 06-21-2011 08:15 PM
carb issues? cosmickites 2-Stroke Dirt Bikes - Kawasaki 4 01-12-2010 02:39 PM
Carb Issues CR125Phil 2-Stroke Dirt Bikes - Honda 1 12-29-2009 09:28 PM
03 CRF 450 Carb Issues! monkeyonahill 4-Stroke Dirt Bikes - Honda 4 10-12-2009 02:45 PM
Carb issues on my 03 450? strykmaster 4-Stroke Dirt Bikes - Honda 13 02-03-2004 09:15 PM
