Old 02-16-2019, 09:09 AM
Last Online: 02-16-2019 09:15 AM
Default Carb Drain Bolt Leak
Hello
I procured a YZ 250F that sat for a long time. The carb was a mess and needed extensive cleaning. I soaked the bowl and all the gunk came off, it is sparkling clean. When I reassembled it gas was flowing out of the bowl drain tube (not an overflow hose). I have cleaned the bowl and the drain bolt several times and it still drains gas out the tube. In the shop manual it does not show any seals and the bolt just blocks off the drain when it seats but mine never does. The drain bolt has no gouges or nicks that might prevent it from sealing. I have never seen this before. Whether the drain bolt is loose or tight, it still leaks.
Any suggestions?
Thanks.
Old 02-16-2019, 04:43 PM
Last Online: Today 03:33 PM
It has an oring.
Go to any oem parts site on line and look it up. That o ring is part of it.
https://www.bikebandit.com/oem-parts...5160#sch528753
Part number 4MX-14561-00-00
That carb and part were used on many carbs of 4 strokes bikes for many years. You can even order the drain plug and the oring as one part off e-bay as well.
Similar Threads for: Carb Drain Bolt Leak
broke transmission drain bolt jawbone 4-Stroke Dirt Bikes - Honda 9 06-21-2011 01:06 AM
TTR 125 Stripped Oil Drain Bolt mnhaq2000 4-Stroke Dirt Bikes - Yamaha 4 05-16-2010 04:19 PM
small filter drain bolt removal 525 exc mick795 4-Stroke Dirt Bikes - KTM 2 07-24-2007 01:12 PM
Rounded off gearbox drain plug bolt daydreamer General Discussion 8 07-22-2007 02:41 AM
stripped drain bolt love 2 ride General Discussion 8 03-12-2004 10:35 AM
