Old 09-08-2007, 04:49 PM
Last Online: 09-08-2007 04:49 PM
Default 250F leaking water from bottom of water pump
Hi guys,
I need some help with my 250F 2003. I just changed the radiator fluid on my bike and all of the sudden, it started leaking radiator fluid from the bottom of the water pump. The water pump has a little hole at the bottom, it seems like it is factory made, but the bike was not leaking before, I was using water ( plain water ) for a while, and now I just put radiator fluid and it leaks now, do you guys have any idea as to why it is leaking?
Thanks guys
LSQRUS
Old 09-08-2007, 05:15 PM
OlSchoolFool393's Avatar
Last Online: 09-12-2018 04:12 PM
Default Re: 250F leaking water from bottom of water pump
Your water pump seal has started leaking.
Hopefully that is the only probley and not a corrosion eaten case
from running only aqua, VERY BAD on aluminum and magnesium
If just water pump seal also replace bearings and impeller
OSF
Old 09-09-2007, 01:05 AM
yzernie's Avatar
Retired now a House Biatch
Last Online: 01-06-2019 09:42 PM
What he said ^^^^.
Similar Threads for: 250F leaking water from bottom of water pump
Water Pump Corrosion SilverCJ-7 General Discussion 5 06-02-2008 04:40 PM
89 CR250R leaking water pump krzywhiteboy 2-Stroke Dirt Bikes - Honda 6 10-15-2007 08:19 AM
CRF450 leaking water pump seal question pjmenez 4-Stroke Dirt Bikes - Honda 11 09-07-2007 09:00 AM
rmz 450 water pump casey392 4-Stroke Dirt Bikes - Suzuki 1 08-30-2005 06:23 PM
KXF/RMZ 250 Water Pump/Oil Cover Fix factory General Discussion 5 10-31-2003 05:59 AM
