2010 Yamaha YZ450F Press Intro VideosThis is a discussion on 2010 Yamaha YZ450F Press Intro Videos within the 4-Stroke Motorcycles - Yamaha forum, part of the 4-Stroke Motorcycle Forums category; I am going on 160 hrs on my RMZ 250 and have only done one valve adjustment. Now I have ... |
#21
| I am going on 160 hrs on my RMZ 250 and have only done one valve adjustment. Now I have a customers CRF 250 with 55 hrs on it and I have already had to replace the intake valves, and re cut the seats. The valve it self went bad not the seats. |
#22
| Yes I'm aware that valves will wear out eventually. But, when the valves are made improperly they wear out faster than normal, which is the problem Honda has had in the past. I don't think it has a dang thing to do with the number of valves in the head. |
#23
#24
| For sure! I don't follow street bikes at all, but I know the R1 has been a 4 valve head for a few years now and I haven't heard of any issues with those. Hopefully it has the same durability/reliability of the older bikes. |
#25
| The R1 does have Ti intakes (SS exhaust). The WR250 still has 5 Ti valves -- the 2010 hasn't been released yet. I really hope I'm wrong and Yamaha's are bullet proof as the other manufacturers are seemingly proving as well. I'm just not sure what Honda's deal is. It would seem that Honda pride stops them from making valves the correct way, i.e., the same way the other manufacturers are. |
#26
| The 2010 250F is a 5 valver, I highly doubt Yamaha will be doing anything major with the WR line this year but it is peculiar that they don't have the specs out yet... |
#27
| The new WR r 250 has 4 valves and FI and 30,000 k valve services, this will be the new engine for the 250 YZ ,WR f bikes in time, maybe next year. As far as Honda, our bike shop sponsor has a shed full of low hour valve job problems waiting to be fixed, pick a cc there all the same he reckons. |
#28
| So the valves are Ti in the WR? |
#29
| Cycle news test: The YZ450F is like no other 450F we've ever ridden: It's ultra nimble, feels extremely light (even though it gained some weight over the '09 YZ), handles well and has tons of useable power - all of the things Yamaha said it would have. And it turns like no other YZ450, too. It stays in the ruts and rarely stands up halfway through the turns. Steering is effortless and it goes where it's pointed, no questions asked. |
#30
IMO there is no way Yamaha would say 30k service limit for valves on a bike that bases it's engine on a high-revving MX machine. I could be wrong, happens many times a day |
#31
Yamaha web site Brand new liquid-cooled 4-valve engine with fuel injection. Adopting the same short stroke dimensions as the YZ250F and WR250F, the Supertrail engine features a compact combustion chamber and a 11.8:1 compression ratio that produces maximum power output at an astonishing 10,000rpm. Large diameter titanium intake valves and high lift cams with excellent follow and lift characteristics allow high rpm levels. Downdraft-type straight air intake layout combined with fuel injection and pent roof combustion chamber result in a quick ignition flame spread. Which in turns means strong power and instant throttle response. Fuel injection system also promotes excellent fuel economy and environmental friendliness. Sensors monitor crank, intake air pressure and throttle position and feed info to a super-compact ECU unit to calculate optimum fuel volume and injection timing. Plated cylinder features a lightweight forged piston with a piston cooler. By eliminating materials with different heat-transmission rates from the liner, cooling efficiency is improved and oil consumption is also reduced. Weight saving wet sump engine lubrication system has fewer auxiliary parts than dry sump. And the new engine’s three axis layout (the relative positions of the crank shaft, the main shaft and the drive shaft) further concentrates mass for improved handling. Smooth operating clutch combines with a six speed gearbox to provide slick shifting and a gear for every occasion. Supersport type large capacity ACM (Alternative Current Magnet) alternator is adopted to provide abundant and reliable electricity supply for lighting, spark and fuel injection system. Spark is further aided by direct ignition coil. A three stage expansion chamber type muffler layout has been designed to bring the muffler closer to the machine’s centre of gravity for lighter handling. Air induction system and honeycomb type catalytic converter enhance environment-friendly performance. Exhaust gases are further filtered by a honeycomb type catalytic converter, which consists of a stainless steel tube coated with platinum and rhodium. The first three section semi-double cradle frame ever on a Yamaha dual purpose model adopts technology from the proven aluminium frames on the YZ250F and WR250F. It consists of cast/forged aluminium main frame mated to a high tensile steel down tube and swingarm. The result is an outstanding blend of weight balance and strength/rigidity. Plush upside down 46mm diameter fork with 270mm stroke provides excellent cushioning while the fork under-bracket is made of high-strength forged aluminium and the handlebar crown is cast aluminium for superior rigidity balance. Slim steel fuel tank is shaped for excellent knee grip. Handlebar, seating and footrest locations create a comfortable riding position for road or dirt. Seat height is lower than WR/YZ at 895mm so a wider range of riders can feel at ease. But ground clearance remains a generous 300mm for serious off road performance. Trick digital display LCD speedo has diagnostic function for fuel injection system as well as stopwatch and distance compensation tripmeter. SPECIFICATIONS ENGINE/IGNITION/TRANSMISSION Type 250cc liquid-cooled DOHC 4-stroke; Displacement - (cc) 250 Bore Stroke - (mm) 77.0 x 53.6 Compression 11.8:1 Fuel Management Fuel Injection Ignition Direct ignition coil Fueltank - (L) 7.5 Transmission Constant-mesh 6-speed;multiplate wet clutch CHASSIS Length - (mm) 2174 Width - (mm) 810 Height - (mm) 1229 Seat Height - (mm) 929 Wheelbase - (mm) 1419 Clearance - (mm) 300 Wet Weight 125kg with 7.5 litres of fuel FRONT END Suspension Front Inverted fork; fully adjustable, 270mm travel Tyres Front 80/100-21 Brakes Front Hydraulic single-disc brake, 250mm REAR END Suspension Rear Single shock; fully adjustable, 270mm travel Tyres Rear 120/80-18 Brakes Rear Hydraulic single-disc brake, 230mm |
#32
Interesting to know since I didn't realise they produced such a bike. I'd say the WR-R will be to Yamaha how the XR range was for the Hondas. A good solid reliable on/offroad bike. I'd bet it would have a bit more oomph than the XR250 though! Just found a review the Courier Mail did on it. You're pretty spot with the service intervals. 1000ks, then 10,000ks then 40,000ks after that. We're on the same page now. |
#33
#34
#35
| I bet it did! But seriously if that's the bike the YZ250F's are following, I like. Didn't think I would see the day when I thought a Yamaha 4-valve MXer would be introduced after the "5 valve ti revolution". Can't wait to buy a little dirt cycle in the next year or 2. |
#36
| Tags |
| 2010 yamaha yz450f, press introductions |
| The 2010 Yamaha YZ two-stroke line-up | DESERTFOX19 | 2-Stroke Motorcycles - General Discussion | 12 | 10-11-2009 09:32 AM |
| 2010 Yamaha YZ450F | SikspakD | General Discussion | 75 | 09-12-2009 04:37 AM |
| 2010 Yamaha YZ250F | MXtras | General Discussion | 4 | 07-21-2009 03:52 PM |
| 2010/2011 Yamaha YZ450F ? | Aus_Rider_22 | 4-Stroke Motorcycles - Yamaha | 26 | 06-09-2009 12:16 PM |
| 2006 YZ450F Introduction and Press Day 11-7-05 | Satch0922 | 4-Stroke Motorcycles - Yamaha | 5 | 11-05-2005 11:30 AM |
