Old 01-08-2020, 03:35 PM
Last Online: 01-08-2020 09:31 PM
Default 2002 YZ426 fuel screw adjustment
I have a question about fuel screw adjustment on my 2002 YZ426, book says 1 3/8 turned out from all the way in? My bike runs good at 2 1/2 out just like basanch 73 said. I go by the book when I work on anything why would we be at a full turn + to run good?. Thank you
Old 01-18-2020, 01:14 PM
Age is a state of Mind
Last Online: 01-18-2020 01:14 PM
Elevation, temperature, and humidity all pay a role in jetting. If you consistently need to run it 2.5 turns out, I would probably suggest going one size larger on the Pilot, but since it's cooler now, that seems to make sense.
If I'm thinking about that correctly.
Also, welcome to ATM
Old 01-19-2020, 12:38 AM
Last Online: 02-01-2020 09:53 AM
The fuel screw is an every day and ride adjustment and is not a fixed setting. The manual gives you a place to start at sea level. Most bikes with that carb call for about 2 turns out as a starting point, so you are not that far off.
Old 01-21-2020, 10:08 AM
Last Online: Yesterday 04:47 PM
If I recall between 1-1/2 turns and 2-1/2 turns is considered normal range. If you run the fuel screw out much farther than that you risk it vibrating loose and falling out of the carb.
Similar Threads for: 2002 YZ426 fuel screw adjustment
86 yz 490 idle screw adjustment mondavy 2-Stroke Dirt Bikes - Yamaha 0 10-10-2011 09:23 AM
Need help on TTR 125 Pilot Air Screw Adjustment Donatello 4-Stroke Dirt Bikes - Yamaha 0 06-23-2009 02:51 PM
How to Tip - 4 stroke fuel screw secrets╩ HOW TO TIP - 4 STROKE FUEL SCREW SECRETS Satch0922 4-Stroke Dirt Bike Knowledge Base 4 02-14-2005 11:04 AM
SME Fuel Screw orange force ATV/UTV Forums 6 12-15-2004 11:19 AM
YFZ Fuel Screw Adjustment: You gotta check this out!!! 2fun ATV/UTV - Yamaha 8 10-14-2004 12:47 AM
