2002 YZ250F..... Off The Deep EndThis is a discussion on 2002 YZ250F..... Off The Deep End within the 4-Stroke Motorcycles - Yamaha forum, part of the 4-Stroke Motorcycle Forums category; I just bought a 2002 YZ250F and have been out a few times. I love this bike and it rips. ... |
| I just bought a 2002 YZ250F and have been out a few times. I love this bike and it rips. However, we were out last Saturday and I took a chance and trying to make it through a puddle which turned out to be a lake (water in the middle was above waist deep and I am 6'2"). When I got it out of the water, the engine was seized, so we took it to the truck, drained all the water, pulled the air filter, cleaned out that compartment, pulled and changed the spark plug and then let it sit for a little while. It started up after pulling the spark plug, but it didn't idle when the choke was put in. I have changed the oil and cleaned the air filter and gave the bike a good wash. I also drained the carb. Any other precautions I should take and if it doesn't idle with the choke in, what could be the problem? Let me know. Thanks. |
| hate to be the bearer of bad news, but i say a bent rod. |
| HUH How do you figure that |
| I was wondering the same thing I'd say pull the carb out, completely clean it (make sure the jets are clear), and reset the float. It's possible that with the rush of water something in there got clogged. Make sure you pull the choke out too and check that. |
| The Following User Says Thank You to D3luxe For This Useful Post: | ||
HitItHard (10-02-2008) | ||
| I was thinking about cleaning the carb. I always get nervous about going that deep into the bike myself. I don't believe anything is broken, I think I just need to do some simple cleaning and like you said, adjust the float and then adjust my idle. I'll keep you posted on if this works. I know a bent rod isn't the case, but thanks for the suggestion. |
| When I read te first response I was like,HUH??How could that bend the connecting rod?If the bike had a bent connecting rod,would it even run? |
| Tags |
| cleaning, idle, mud, start, water |
| 2002 yz250f | wf4891 | 4-Stroke Motorcycles - Yamaha | 7 | 10-31-2006 04:05 PM |
| Probably Buying A 2002 YZ426F/YZ250F | GlennO | 4-Stroke Motorcycles - Yamaha | 5 | 10-05-2006 07:04 PM |
| 2002 yz250f valves | Racer#857 | General Discussion | 1 | 08-02-2006 10:54 PM |
| Who will do a good job on a 2002 YZ250f? | MXracer250F | Motorcycle Suspension Tuning | 3 | 10-25-2004 10:47 PM |
| 2002 YZ250F for sale | thumperjumper | 4-Stroke Motorcycles - Yamaha | 2 | 12-09-2003 10:08 PM |
