![]() what is involved in doin the auto decomp cam insall is it as easy as swapin the cams? |
![]() yes, it is. Just put the '03 in and go. My buddy had great luck with his once he made the swap. |
![]() yes it is a easy swap. i had a 02 that i did it to. all u need is the cam from a 03. No other parts needed. It worked well. |
![]() thanks guys does it make it easier to crank cause right now its a pain |
![]() you either dont have the cam timing correct or the valves shimmed properly because it should kick right over. It holds one valve open so there is no compression in the cylinder |
Thread Tools | |
2002 YZ250F..... Off The Deep End | HitItHard | 4-Stroke Dirt Bikes - Yamaha | 5 | 10-02-2008 11:48 AM |
2002 yz250f | wf4891 | 4-Stroke Dirt Bikes - Yamaha | 7 | 10-31-2006 04:05 PM |
2002 yz250f valves | Racer#857 | General Discussion | 1 | 08-02-2006 10:54 PM |
Who will do a good job on a 2002 YZ250f? | MXracer250F | Dirt Bike Suspension Tuning | 3 | 10-25-2004 10:47 PM |
2002 YZ250F for sale | thumperjumper | 4-Stroke Dirt Bikes - Yamaha | 2 | 12-09-2003 10:08 PM |
