Old 03-17-2011, 10:00 PM
Last Online: 03-29-2011 04:29 PM
Default '06 yz450f problems starting..please help!
i have an '06 yz450f, it takes a million kicks to start it and when i do get it to start(rarely) it runs very hot, backfires alot, and stalls. I get good spark and have fresh fuel....what else may it be? Please help as i dont have the money to pay a dealer to fix it and just wanna ride. I have a service manual and nothing seems to add up.
-Thanks in advance
Old 03-17-2011, 10:09 PM
supercr125's Avatar
Last Online: 03-01-2016 11:12 PM
could be your valves, it sounds like they need adjusting, whens the last time they were touched?
Old 03-17-2011, 10:17 PM
i just replaced 3 out of the 5 shims that were out of spec cuz thats what everyone was saying. Now, it was my 1st valve job, i followed the service manual and watched a ton of vids on youtube...but it was acting the same before as it is now
---------- Post added at 09:17 PM ---------- Previous post was at 09:15 PM ----------
could it be the timing...if so how do you set the timing cuz it doesnt say too much in the manual
Old 03-17-2011, 10:34 PM
supercr125's Avatar
i have no idea how to work with the timing on newer bikes sorry.
Old 03-17-2011, 10:37 PM
thanks...im gonna recheck my valves tom
Old 03-17-2011, 10:56 PM
2strkyz's Avatar
Last Online: 04-22-2012 12:39 PM
It sounds like it is running lean. Try first adjusting your fuel screw to richen the mixture(that would be turning it out) and see if it improves. If that doesnt help pull the pilot and main jet out and clean them. Take particular care in making sure the pilot is clear and that it is of an appropriate size(did the bike run well previously?).
If the bike were mine and it was running fine before, I would just pull the main and pilot jets, clean the main and pilot as well as giving the carb a good clean. Then set the fuel screw at 1.5 turns out.
Sometimes i just replace the pilot jet with a new jet of the same size.
Old 03-18-2011, 10:03 AM
the bike has been sitting for about a year now so i will try that and ill get back w how it went...maybe ill get lucky
Old 03-29-2011, 04:29 PM
okay guys...sorry its been a while i havent had the time to work on the bike, but heres a few more things that may lead you too more ideas that could help me. When i first got the bike it started and ran but took about 15 or 20 kicks and ran hot, stalled once it got too hot and backfired alot. So by what i was told i checked the valve clearances and found there were 3 off so i replaced them with the correct sizes and now it wont even start. As far as the timing goes, you line up the dots on the camshafts at 9 o'clock and 12 o'clock for exhaust and 12 o'clock and 3 o'clock for intake and line up the mark on the hole at the bottom end seen through the plug hole. Is there anything wrong w anything ive done, is there anymore to timing it (timing light maybe).
Old 03-29-2011, 11:05 PM
2strkyz's Avatar
jetting, fix it
Similar Threads for: '06 yz450f problems starting..please help!
YZ 250 starting problems mboyd 2-Stroke Dirt Bikes - Yamaha 4 06-04-2008 06:39 PM
Starting my new YZ450F.. joseph13 4-Stroke Dirt Bikes - Yamaha 2 04-30-2008 04:43 PM
04 yz450f starting issue ken_atm 4-Stroke Dirt Bikes - Yamaha 8 11-15-2006 07:58 AM
Starting problems KTM 450/04 fastbike 4-Stroke Dirt Bikes - KTM 13 04-13-2004 03:45 PM
starting problems, 450 dawg2227 4-Stroke Dirt Bikes - Honda 6 03-20-2004 09:25 PM
