03 Gas tank fit a 02?This is a discussion on 03 Gas tank fit a 02? within the 4-Stroke Motorcycles - Yamaha forum, part of the 4-Stroke Motorcycle Forums category; After I install my 03 cam, get a re valve, and remote hot start the onlything keeping my 02 250F ... |
| After I install my 03 cam, get a re valve, and remote hot start the onlything keeping my 02 250F from bieng a 03 will be the gas tank so I was wonduring if I got new plasctics will the 03 tank fit a 02? Thanks |
| I remember a guy on TT talking about changing his 426 plastics to 450 but I believe it was much more intensive then just changing the tank.. If my memory serves me right I believe he had to change the subframe, tank, seat, sidepanels, rad shrounds, and air box. It might be worth some research before you get a tank. |
| I heard the same thing about changing everything. The '03 stuff is supposed to be lighter, but I don't know if it would be noticeable |
| no, different frame |
| Its probably not worth all the extra money to replace all the plastics. By the way, yamaha250F and i were talking on aim the other day about his motor. His bike is 1yr old, and besides regular oil changes and cleaning the air filter he really hasnt done any work at all to the motor. Since he is going to have the motor apart to swap out cams, he was wondering what other stuff he should do while inside the motor. I was thinking mabye just a new set of rings, mabye a piston and to shim the valves. What do you guys think? |
| had a buddy do that. just do the shims and check the intake(shims) for wear. But you will have to resuze your exhaust shims forsure. |
| so do you think it is due for a piston mabye? |
| i'd say at least a set of rings Dell, as for the tank thing, i think the frame for the 02 is different from the 03, so no go on that. i doubt seriously the weight savings would be noticeable. what you do is: next time some punk on an 03 250f asks smugly "what year is that thing? are ya [i]sssuuuurrrre[/u] you wanna race me against my much better '03??" tell him "oh its an 02, but your goin down hawnkie" and blow him away because you have a 03 250F under 02 disguise Rob |
| I think some of that weight savings would be the new sub-frame and seat, but you probably wouldn't be able to tell |
| very true MXXX. good call |
| do you have a big lost of power? is it smoking?Mine is a 02 and I don't need them yet. It's not a 2 smoke. But yes the valves should be checked. |
| no big loss of power, no smoke, still starts well... I think he just wants to make sure he wont have to work on it for at least another year. |
| When I put the new cam in I may or may not have to re shim but I do want to put a new timing chain in. Is it very hard to do? |
| -->> 96-01 YZ250 tank conversion to 02-08 tank conversion made simple <<-- | phantomette | 2-Stroke Motorcycles - Yamaha | 4 | 08-25-2008 01:53 AM |
| 01-06 RM 250/125 gas tank | chris642 | Wanted Items | 1 | 11-24-2005 10:52 AM |
| ims tank | zakspeed | Wanted Items | 3 | 02-14-2005 05:02 PM |
| gas tank for xr 250 | Newf_Rider | 4-Stroke Motorcycles - Honda | 13 | 05-20-2004 02:41 PM |
| ttr 125 gas tank | yamahaboy | General Discussion | 1 | 10-03-2003 09:56 PM |
