01 YZ 426 won't start :cry
This is a discussion on 01 YZ 426 won't start :cry within the 4-Stroke Motorcycles - Yamaha forum, part of the 4-Stroke Motorcycle Forums category; Alright guys I need some help from you, I got an 01 426 and it won't start up for me. ...
Old 11-06-2009, 05:09 PM
Last Online: Today 08:14 PM
Unhappy 01 YZ 426 won't start :cry
Alright guys I need some help from you, I got an 01 426 and it won't start up for me. I replaced the sparkplug and it still won't start up. Its getting spark and fuel but it won't start.
Old 11-06-2009, 05:52 PM
Last Online: Today 06:47 PM
When did you last check the valves?
Has the carb been cleaned or checked out?
How new is your fuel?
Are you following the proper starting procedure?
Have you done the ritualistic dance and sacrificed a chicken to the Yamaha gods?
Old 11-07-2009, 07:40 AM
Mainjet2001's Avatar
Last Online: Today 01:06 PM
Has the bike been setting a long time?
If so, it may need the carb cleaned.
Old 11-07-2009, 11:06 AM
yzernie's Avatar
Moto Geezer
Last Online: Today 06:43 PM
When you pulled the plug out was it wet with fuel?
Old 11-10-2009, 05:14 PM
Moto
Hey guys,today I had it running but it is hard to restart after it's been running. :Jedi
Old 11-11-2009, 04:21 PM
kwmotocrosspunk's Avatar
Im SOUNDERS Till I Die!
Last Online: Today 05:44 PM
check valve specs and decomp./hotstart valve
Old 11-11-2009, 05:33 PM
I've been RM-Zedded
Last Online: Today 01:39 PM
Yep, I would take a look at the valves.
Old 11-11-2009, 08:54 PM
monkeyonahill's Avatar
Free Rider
Last Online: Today 05:59 PM
yep, i give a 3rd on checking valves.. dang 4-strokes.. hard starting is a pretty good sign on a thumper of out of spec valves.
Old 11-12-2009, 04:16 PM
Usflag
The weird thing is that when it runs it will run like crazy but just when it dies if im lucky it would start up but any other time it won`t start up
Old 11-12-2009, 04:36 PM
I've been RM-Zedded
Have you ever adjusted you AP Timing? That could also be a problem. You could be squirting too much fuel or at the wrong time (or both) which could make for a tough starting bike as well.
I'd still look at the valves though -- It's pretty easy --> http://www.allthingsmoto.com/forums/...-valves-47609/
Old 11-13-2009, 09:00 AM
Usflag
That ccould also be the problem because when I try to start it, it would backfire
Old 11-13-2009, 01:54 PM
I've been RM-Zedded
That is also a symptom of valves needing adjustment.
Old 11-16-2009, 10:15 AM
Don't twist the throttle when you are trying to start it!
Old 11-16-2009, 04:31 PM
It still would backfire even when I don`t touch the throttle
Old 11-16-2009, 05:04 PM
I've been RM-Zedded
You could also have a header pipe leak which would cause that as well... But again, it still points to your valves needing adjustment.
Old 11-17-2009, 12:58 AM
Macho393's Avatar
CROSSTHREADED RACING
sounds like your carb is jacked up.If its your valves it would start easy once hot, IMO.
Old 11-17-2009, 01:12 AM
I've been RM-Zedded
Mine didn't start with a darn hot or cold when it was out of spec. It wouldn't idle, and it back fired like mad too.
Old 11-17-2009, 05:27 PM
Today I started it up while it was warming up the header pipe turned red-orange hot, would it sucking air cause it to do this or would a bad TPS cause it to do that?
Old 11-17-2009, 07:45 PM
I've been RM-Zedded
running it for 5 minutes with no air flow would cause that. These bikes don't have fans to force the air through the rads, so they get pretty hot pretty quick if they are not moving.
Old 11-17-2009, 08:52 PM
Yea but, it turned in less than a minute. When I was riding it everytime I would pull the clutch in the rpm's would go up, the idle screw as low it would go without stalling the bike.
Similar Threads for: 01 YZ 426 won't start :cry
89 cr 80 no start john ward 2-Stroke Motorcycles - Honda 5 11-22-2008 08:37 PM
Won't Kick Start But Will Bump Start RoostRM125 2-Stroke Motorcycles - General Discussion 38 02-22-2008 06:06 PM
Cant start my kx 250 buck12point2009 2-Stroke Motorcycles - Kawasaki 4 09-10-2007 07:30 AM
OT: i want to start my own..... TRXman86 General Discussion 8 04-29-2004 12:01 AM
Won't Start???!!! 83SuzukiRM250 General Discussion 15 01-19-2004 10:39 AM
