tire pressure for sandy tracksThis is a discussion on tire pressure for sandy tracks within the Motorcycle Riding Tips forum, part of the Dirt Bike - ATV - Suspension Forums category; when riding on sandy tracks does the tire need to have less air than normal? if so how much less ... |
| when riding on sandy tracks does the tire need to have less air than normal? if so how much less psi? |
| Living in Florida I ride sand all the time and have blown many inner tubes riding with low air in the tires.So I just run 14 in the rear and like 12 in the front |
| The unwritten rules as I know them are a soft tire for a hard track and a hard tire for soft track - not just compound, but profile as well. Tread pattern should be correct for the terrain and soil. Less pressure flattens the contact area and creates more grip on a hard track. I would be cautious running any less than 12 PSI - you run a greater risk of pinching a tube or dinging your rim. I think you are better served by using the correct tread configuration and compound for the conditions and making only minor changes in pressure. Scott |
Flattening the surface of the tire by less air is actually for sand but it is useless for a bike because the tube will pinch.But your right about the correct tire,I like to run dunlop 756's for almost everything but hard terrain. |
| Hey Cody - have you ever tried the 755 for sand? It about as close to a paddle tire as the AMA will allow. I ran a 755 front and rear at a few Beach-crosses (very deep sand) a few years ago. It works better in deep sand than the 756 (what i usually run otherwise). The 756 is an awesome tire for the rest of the terrain I ride. Scott |
| I've never seen the 755 but I'm running a 773 on the rear of my CRF250R and am very happy with it. On my KX250 I'm running a Pirelli Lagunacross MT44 and it's the best sand tire I have ridden with bar none but for some reason I think Pirelli discontinued them. Both bikes: 12psi front, 10psi rear. Last edited by BHECTUS; 01-20-2009 at 05:37 PM. |
The tire link I provided has the new perelli tire and it is very close to the one you had. |
| Tire Pressure??? | IslandRide | General Discussion | 11 | 07-25-2008 11:09 PM |
| tire pressure | oppo | General Discussion | 3 | 05-31-2007 07:04 AM |
| Tire Pressure Help | Whiiterabbitt | 2-Stroke Motorcycles - Kawasaki | 12 | 11-20-2006 05:50 PM |
| conditions for sandy tracks | Thump_This | General Discussion | 12 | 02-20-2004 09:38 PM |
| Tire pressure for Sand tracks | AndrewPA | General Discussion | 5 | 07-26-2003 10:21 AM |
