Quantcast Quick question about jumping
Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > Motorcycle Riding Tips
This is a discussion on Quick question about jumping within the Motorcycle Riding Tips forum, part of the Dirt Bike - ATV - Suspension Forums category; Well, when reading about jumping, I always see "Just keep a steady throttle up the jump and don't let off ...
Old 06-13-2008, 10:59 AM
jhendrix's Avatar
Vroom Vroom
Last Online: 01-03-2009 12:11 PM
Default Quick question about jumping
Well, when reading about jumping, I always see "Just keep a steady throttle up the jump and don't let off or you'll endo".
Well, I have a problem then, because if I keep throttle all the way up the face, I go really nose high. And, if I let off a little before, I stay nice and even.
Could it be my suspension, or maybe the faces of the jumps?
Any suggestions/tips?
Thanks.
Old 06-13-2008, 12:01 PM
crfjedi393's Avatar
Obi Wan Kenobody
Last Online: Today 10:45 AM
Default Re: Quick question about jumping
Throttle control is not the main thing I use to maintain a favorable bike position. Body position is one of the most important things when jumping. Experiment over and over on the same jump. Preferably a nice easy table top so you can short jump it. Experience will teach you where you should be on the bike. It may only take an inch or so of movement to make a difference. Eventually you will gain confidence and you'll know what to do on different faces.
It's hard to teach/learn jumping on a forum. There are lots of variables.
Old 06-13-2008, 12:27 PM
jhendrix's Avatar
Vroom Vroom
I'm definitely going to try that next time out. Thanks for the tips.
Old 06-13-2008, 01:46 PM
I've been RM-Zedded
Last Online: Yesterday 07:11 PM
Though I agree with Jedi, I do not discount/ignore bike setup.
From the sounds of it, your rebound might be a little slow -- if you so choose, you could click 2 clicks on your shock rebound in the H direction (harder/stiffer/faster) to make it rebound just a tad faster, which will in turn will help level your bike out in the air while keeping the throttle steady.
Old 06-13-2008, 02:30 PM
jhendrix's Avatar
Vroom Vroom
Awesome. Thanks! I was just reading up about adjusting suspension, so next time out i'm going to make adjustments and find what I like.
Thanks again!
Old 06-13-2008, 02:48 PM
I've been RM-Zedded
the "What I like" is key here.
Also make sure when adjusting suspension that you only and I emphasize the ONLY adjust one setting at a time. It's also a good idea to know the original setting before you start clicking in case you royally mess it up you can just start over.
Old 06-13-2008, 03:48 PM
jhendrix's Avatar
Vroom Vroom
Hmm, what do you mean by "adjust one setting at a time"?
Like...adjust front forks some, and only front forks..and then once I get that the way I like it..adjust rear shock?
Or, other way around? Or...what?
Thanks!!
Old 06-13-2008, 04:32 PM
Shoei_391's Avatar
Rebuilding the KDX
Last Online: 11-29-2008 12:18 AM
I think he means that when you go adjusting the clickers, do it one at a time?
Old 06-13-2008, 04:47 PM
jhendrix's Avatar
Vroom Vroom
Hmm..good point. I think that's what he may have been talking about.
DRGSin393's Avatar
Have you adjusted ur float
Last Online: Today 01:18 PM
Theres also a 2 stroke-4 stroke difference. if you stay on the gas all the way thru the face on a 2 stroke the front end will go up. You need to stay on the gas all the way up for a 4 stroke so it wont endo.
Old 06-13-2008, 06:13 PM
I've been RM-Zedded
Sorry, I mean if you change the rebound on the shock, don't change anything else suspension wise period until you ride it. You'll want to verify that the changes you make are what you want. IF you adjust the rebound and the compression on the shock and you hate it, you won't know for sure which change made it suck.
It's a lot easier to fine tune, and it's easier to not get confused.
Old 06-13-2008, 06:21 PM
crfjedi393's Avatar
Obi Wan Kenobody
Suspension set up is very important. That's what I meant when I said "there are lots of variables". When you eventually get your suspension set where you want it, you will still need to pay attention to body position on jumps with different faces. Maybe just start with dialing in your suspension but eventually, you will need to consider all of it. High winds from different directions will add other factors.
Good advice in this thread.
Old 06-13-2008, 06:45 PM
jhendrix's Avatar
Vroom Vroom
Ahh. Got it! I'm definitely going to make some adjustments to suspension and work on body position. Thanks everyone!!
Old 06-13-2008, 09:10 PM
Miles711's Avatar
Hondanaut
Last Online: Yesterday 11:54 AM
Another thing to consider is the fact that the hold the throttle steady rule was made with big four strokes in mind. Your 125 smoker doesn’t have near the engine breaking as my 450f does, and that will contribute to you staying nose high while using the same technique I would on the thumper. If your hard on the gas all the way up the face you will want to bring your upper body forward during the middle part of your "hang time" to drop the front end. Its especially bad when you seat bounce something under full throttle, but body positioning in the air can fix just about anything. Eventually you can learn to use a brake tap, but I could concentrate on proper body positioning before moving on to that (I'm still working on my body position a lot as well).
Body position is something that’s hard to change by yourself, because your feeling of what you think your doing doesn't always match what your actually doing. I've had to do alot of work recently on staying in the attack position in the air.
Here is a picture of using body position to fix a really nose high bike (just to give you an idea of how far forward you can really get).
That jump kept sending me vary nose high with the way I was hitting it, so I had to really correct it with body position.
Here is one where it felt like I was getting far enough forward, but the front end of the bike never leveled. It took me awhile to get over that issue.
What you’re looking for is the nice attack position. That’s something I'm still working on to get consistent with it.
You don't necessarily have to get over the front fender, but at least get your center of mass over the bars and it will start to bring the front end down. The earlier in the jump you do it, the more your front end will drop. I have also found that right before you land if your coming in nose high you can push down with your arms to drop the front end a bit right before impact.
Everyone has different styles, and seat time to get comfortable with your body position is the key!
Old 06-13-2008, 09:43 PM
