Quantcast List of cheap fixes and helpful hints
Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > Motorcycle Riding Tips
This is a discussion on List of cheap fixes and helpful hints within the Motorcycle Riding Tips forum, part of the Dirt Bike - ATV - Suspension Forums category; I would say this goes hand in hand with riding tips, bike tips. I was just wondering what little hints ...
Old 08-25-2008, 09:23 PM
racerfty's Avatar
Last Online: 11-20-2008 06:18 PM
Default List of cheap fixes and helpful hints
I would say this goes hand in hand with riding tips, bike tips. I was just wondering what little hints and tips are out there to fix little problems on the bike. for example i do alot of gncc racing and i know that the mud and water getting on riding boots and kick starter make for some extra kicks due to foot sliding off, i discovered intalling zip ties on the kick starter helps. Along with the fact they are cheap to install, funtional and cheap to replace. So what other tricks and hints are out there?
Old 08-26-2008, 04:20 PM
ktm_cody_199's Avatar
125 B stock
Last Online: Yesterday 07:16 PM
Default Grip Tape
This is good idea,I have an 07ktm250sxf and the paint likes to wear away on frame.To keep it looking good I put grip tape from a skate board on where my boots rub to keep it looking sharp and adds extra grip for muddy races.When it gets really muddy I put grip tape every where!!Levers,subframe air box covers,under the back fender for some where to grab when lifting out of mud.tool kit in camel back and a special compartment for LOTS-O-ZIP TIES.A nice clean rag in my camel back just in case you get some serious mud on your face and hands.
Old 08-26-2008, 04:29 PM
pjg351's Avatar
Tie me Kangaroo down sport
Last Online: Today 04:34 PM
Default Re: List of cheap fixes and helpful hints
When i get a new bike, i put a dab of silicon sealant on all the plastics bolts. This stops them vibrating loose but doesn't grab hard like lock tight glues do.
Old 08-26-2008, 05:14 PM
125 B stock
Well that is a good idea
I spray pam under my fenders and on my mud flap so nothing big sticks to it.
Old 10-09-2008, 04:43 PM
racerfty's Avatar
Got a new one, i have been having problems with items hitting my valve stems and causing them not to seal, after i fixed them, or replace the tube, i started putting the valve stem cap on, and using a small piece of sponge cut into a square with a hole in the center of it and sliping it over the valve stem, so far so good, i just have problems finding the sponge after a good pressure cleaning.
Old 10-09-2008, 06:57 PM
125 B stock
Im confused?How does that work
Old 10-10-2008, 08:33 PM
racerfty's Avatar
by putting the sponge on the valve stem, it reduces the energy from a stone or any other item hitting the stem and compresses the sponge, and not transfering as much energy to the stem, it wont help if you dead on a root or something, but it helps for those roost pebbles.
Old 10-11-2008, 07:20 PM
JS89's Avatar
Last Online: Today 12:52 PM
spray paint works good as grip glue
Goof-off work good to clean plastics off good were it scratched
when puting new tires on put baby powder in the tire move around KEEP tube from sticking to tire TUBE LAST LONGER Done use WD-40 dosent dry and will casue your tire to spin on the rim
Old 10-13-2008, 04:57 PM
racerfty's Avatar
With the wd-40 i had the best lock with it for spinning new tires on, if i use soap and seat the bead, it takes a while for the soap to wear off, and when i run low pressures the bead will back off. If i use wd40 and seat the bead, i can lower the pressure down to 7-10 psi and ride with out a problem, my bike has a bead lock so spinning the rim, really dont happen. I like the baby powder, i will have to try that.
Old 10-13-2008, 05:18 PM
JS89's Avatar
Smile
WD-40 dosent dry and it will cause the tire to then causeing the vavle stem to get ripped out and it also bonds the tube to the tire and tube dosent last long at all
Old 10-13-2008, 08:48 PM
pjg351's Avatar
Got this of TT, for your plastics
Removing flex marks and scratches from plastics
Got white flex marks on your plastics?
Tools needed: cleaner, heat gun (adjustable works best)
Work description: Clean the plastics, take the heat gun and slowly heat it from the back side. Slowly heat until the plastic is changing the color. Let it cool and you´re done. In some cases you need to treat both sides. Test the procedure on some old parts first to get a feeling for the right temperature.
Got scratches on your plastics?
Tools needed: Sand paper (#100 - # 1000), cleaner, heat gun (adjustable works best)
Work description: Wet sand the plastics starting with the low grain first (# grain depending on the depth of the scratches) und finish with #1000 sand paper. Clean the plastics. Slowly heat until you see the plastic changing the color sort of like starting to melt. Let it cool down and you´re done. Test the procedure on some old parts first to get a feeling for the right temperature.
Old 10-13-2008, 09:16 PM
Freak's Avatar
Hook 'Em
Last Online: Today 03:21 PM
Better to keep the tube dry so it don't move around. That's when valve stems go bye bye.
Old 10-14-2008, 09:48 AM
MXtras's Avatar
Manufacturer
Last Online: Today 10:19 AM
Keep your levers loose enough that they rotate rather than break in the event of a crash. Make sure the ends of the levers do not extend past the end of the bars.
Get a few spare air filters for your bike. Clean and oil them all at once putting them in bags for future use - this promotes good filter changing habits.
To properly align your chain, spin the wheel and adjust so that the chain runs in the center of the sprocket with an even gap between both sides of the chain and the sprocket. This works best on new chains - it's not too consistent on a used chain but still aligns it mechanically true better than the marks on the axle blocks.
Baby powder works well for short term use but using heavy duty silicone spray works better in the long term for keeping the tube free inside the tire. Keep all oils away from the bead.
WD-40 sucks for just about everything. It will rot rubber and most elastomers.
Scott
Old 10-14-2008, 10:24 AM
MotoMan's Avatar
Floppy
Last Online: Today 02:29 PM
When installing new grips use hairspray to allow the grips to slide on easily, then saftey wire the grips in place so they NEVER move. About the easiest most full proof method I have found.
Old 10-14-2008, 04:13 PM
char393's Avatar
Incretacular!!
Last Online: Today 04:54 PM
Hey, that's my method! Exactly why I have a can of hairspray in the garage.
