Bogging ProbsThis is a discussion on Bogging Probs within the Motorcycle Riding Tips forum, part of the Dirt Bike - ATV - Suspension Forums category; Everything is fine, but when i corner tight it bogs....is it because i am not giving it enough gas or ... |
| Everything is fine, but when i corner tight it bogs....is it because i am not giving it enough gas or what?? Simple yet aggervating feel like i am losing speed |
| I'm not sure I follow.... Are you having bike problems or are you just not giving enough gas? |
| I dunno to tell you the truth, i corner, wheeles spin like they should.Then all of a sudden it bogs slightly then its fine, only does this when i turn sharp like 180turns. Last edited by YZ450Rider; 05-06-2008 at 05:41 PM. Reason: I am stupid |
| Sounds like maybe when you lean it over maybe fuel is leaking out your carb maybe. Possibly the float in the carb needs to be adjusted |
| Hmmmmmmm...... is it a quick fix? Or am i going to have to take apart the whole carb to get to the float valve? |
| You will have to remove the carb, but it's located in the float bowl, so it's not that difficult. Just takes some time and you will need to know what the spec is so you can adjust it correctly. |
| Will it all be in the owners Manual? |
| Might be.. not sure. |
| yea i would say check the carb you ride a 4 storke right it could be valves but i do go with carb frist or next time u ride clutch it and pin it hard see if it helps who knows maybe maybe not . |
| Clutch Probs | kawaboy22 | General Discussion | 0 | 05-02-2008 01:25 PM |
| Carb Probs! | jimz360 | 2-Stroke Motorcycles - Suzuki | 0 | 02-26-2008 04:53 PM |
| RM 250 98 model probs | RMer98 | 2-Stroke Motorcycles - Suzuki | 5 | 06-23-2007 05:15 PM |
| Help swing arm probs | jambo | Motorcycle Suspension Tuning | 5 | 12-18-2006 01:19 AM |
| esr pipe probs | Vinny3299 | ATV/UTV - Yamaha | 10 | 07-27-2005 10:43 AM |
