Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > Dirt Bike Riding Tips
Old 07-14-2013, 03:29 PM
Last Online: 07-12-2015 08:13 PM
Default Bike fishtails on loose dirt
I don't know if this is the right place but I have a 79 suzuki ds125 and it fishtails on loose dirt could be I have to much pressure in the back tire? It has 30psi as does the front
Old 07-14-2013, 04:50 PM
stevo450's Avatar
On loose dirt any bike will do a little fish tailing
Old 07-14-2013, 05:12 PM
Last Online: 05-22-2019 08:12 AM
That's a lot more air than I use but I'm in totally different terrain. For motocross I run between 11 psi to 17 psi. Riding trails I'm usually at the higher end up to maybe 20 psi max. In sand I'm at the opposite end around 11 psi.
Old 07-14-2013, 05:53 PM
So should I drop some air out of it down to 20 psi? I expect some especially haulin buns on it lol but there's one trail over here that I have to creep down bc it fishtails so bad
Old 07-14-2013, 07:37 PM
YamahaRT's Avatar
Last Online: 04-15-2014 09:52 AM
It fishtails when you're going downhill in loose dirt? Then you probably aren't giving it gas, and the engine compression braking is strong enough that your rear wheel is sliding a wee bit, thus making it fishtail. As to tire pressure you are about 10-15 pounds overinflated-I run 15 psi almost all the time.
Old 07-15-2013, 07:09 AM
FRODAD393's Avatar
Last Online: 03-19-2017 09:03 AM
Your rear shock could be in need of a rebuild. Need to slow it down, whens the last time is was serviced?
Old 07-15-2013, 09:29 AM
Silver_Fox's Avatar
Last Online: 02-22-2017 09:36 AM
Won't be much you can do with the boingers on a '79 DS
Old 07-15-2013, 11:17 AM
FRODAD393's Avatar
Put some bricks in your pants? Or go on the RC cheeseburger diet?
Old 07-15-2013, 01:48 PM
YamahaRT's Avatar
He has no problems :
better make that plural,,,lol, 30 sounds hight, but if the tires is designed as on and off road it may require it. check the manufacturers website
Similar Threads for: Bike fishtails on loose dirt
New to the dirt bike. bustedCR125 2-Stroke Dirt Bikes - Honda 5 03-20-2013 09:33 PM
Trade the mountain bike in for a dirt bike xcracer Dirt Bike Riding Tips 7 11-27-2012 05:27 PM
im looking to get a new dirt bike shaynske What Dirt Bike or ATV 8 07-26-2012 02:42 PM
Help me understand traction (loose dirt vs hard packed) mxmama393 Dirt Bike Riding Tips 37 09-18-2007 09:56 AM
dirt bike for dirt "yes" but sand???? CR Chick 4-Stroke Dirt Bike Bike Forums 30 09-25-2004 09:11 AM
