Go Back   All Things Moto! Web Forums > Dirt Bike - ATV - Suspension Forums > Motorcycle Riding Tips
beginners tricks
This is a discussion on beginners tricks within the Motorcycle Riding Tips forum, part of the Dirt Bike - ATV - Suspension Forums category; hey whats the easiest tricks to start out with? share what your first tricks were and how u mastered them!...
Old 07-09-2007, 03:26 AM
jum's Avatar
jum jum is offline
Last Online: 11-06-2007 03:28 AM
Default beginners tricks
Old 07-09-2007, 03:51 AM
Restless45079's Avatar
Last Online: 12-13-2007 07:32 AM
Default Re: beginners tricks
The first trick I tried was a no footer. Just try it on a jump that you are comfortable with and get decent air with. Then you just start small. After a while I was trying heel clickers. But make sure you stretch your groin or you'll be hating life. Just make sure you are prepared to eat dirt, it happens. And don't go big the first day out. Broken collar bones never heal right.
Old 09-11-2007, 11:54 PM
Rm rider 69's Avatar
Last Online: 09-08-2008 05:36 PM
i started with no footers one went wrong and now i can land side saddle no handers ad supermans arent tooo hard jus commit
Old 09-12-2007, 04:13 AM
JDR215's Avatar
Last Online: Yesterday 11:54 PM
the double fist pump is doin it for me right now, i am practicing it for the time when i actually get a good finish.
Old 09-12-2007, 07:16 AM
triplendo's Avatar
Moto Enthusiast
Last Online: Yesterday 02:38 PM
Usflag Re: beginners tricks
Mine is hands on the bars, feet on the pegs and going around the track as fast as I can without buying the farm!!
Old 09-12-2007, 08:38 AM
mxmama393's Avatar
Niffer
Last Online: 11-03-2009 10:45 PM
I second that one.... once I master keeping the rubber side down, and pick up a little speed doing so, Ill feel like Ive concurred the world!
Old 09-12-2007, 09:08 AM
noobish's Avatar
Getting faster
Last Online: 11-19-2009 04:47 PM
I dont see why people take their arms and legs off of their bikes. I am so busy holding on for dear life I dont dare take a thing off!!!!
Old 09-12-2007, 09:28 PM
cjacobs's Avatar
Last Online: 10-26-2008 02:48 PM
I've been practicing hitting the back brake to bring the front wheel down while air-born, so far, I've killed the engine five times, but I'm not high enough to hurt myself, I just land with the engine off and it turns over after a quick lurch forward. I have to remember, stab the brake, once the wheel is stopped, take the foot OFF the brake. It's hard for me to feel exactly where my foot is when I'm wearing boots. Anyway, I'm getting better and self improvement is what it's all about.
Old 09-12-2007, 09:30 PM
char393's Avatar
Incretacular!!
cjacobs, just curious, do you clutch when doing the brake-tap?
Old 09-12-2007, 09:35 PM
cjacobs's Avatar
Yes, I pull the clutch in, but it's the "tapping" part I have to work on, since I don't have a good feel for the brake lever with my boots on, I tend to keep my foot on the brake when I let the clutch back out. Also, I have to take my fingers off the handle bar, otherwise, my fingers get in the way and I can't pull the clutch in far enough. It might need some adjusting. The other problem is, if I adjust the clutch so that I can leave my fingers between the clutch and the handle bar, I can't reach the clutch, seems my fingers are too short.
noobish's Avatar
Getting faster
Are you supposed to use the clutch when brake tapping in the air? What about corners? I am having a lot of trouble with corners,trying to get faster thru them. I have been hitting the break to slide into them and sometimes I use the clutch and sometimes I dont, I am not sure which is correct.
Old 09-12-2007, 09:37 PM
cjacobs's Avatar
I think you'd better use the clutch whenever you use the brake, otherwise, the engine will stall unless your brake pads are worn out.
Old 09-12-2007, 10:35 PM
char393's Avatar
Incretacular!!
gotcha
I am not confident enough to try a brake tap, I was just curious. I clutch and brake with only one finger as that seems to work best for me. I don't have big hands... I think? LOL
Old 09-13-2007, 01:27 PM
cjacobs's Avatar
Well, now I’m thinking that the clutch is disengaged just fine with my fingers between the lever and the handlebar, I probably was leaving my foot on the brake and thinking it was the clutch not disengaged when the engine stopped. I’ll have to test that. Char, you should try the brake tap over a small jump, there’s nothing like the feeling of accomplishment! After I get that down, I’m going to start working on shifting in the air. Then… a whip!
Old 09-13-2007, 05:10 PM
schwen_108's Avatar
Last Online: 10-09-2009 11:21 PM
FIST PUMP!!!!!!
Old 09-13-2007, 05:15 PM
The Baron's Avatar
Problematic Poster
Originally Posted by schwen_108 View Post
FIST PUMP!!!!!!
Yup!
I always practice to keep my back straight, butt out, elbows down, chin up, knees out and toss out a fist pump whenever I cross the finish line. This always gets the crowd goin'!
Butt-Whips are also a crowd pleaser.
Old 09-13-2007, 07:23 PM
basanch73's Avatar
Four20Sixer
Last Online: 07-16-2008 10:07 AM
I had the same problem with the clutch until I got the ASV set up that allows you to adjust the lever in and out to suit your finger reach after you adjust the cable where you need it. Well worth the $60 and a warranty to boot.
Old 12-21-2007, 10:50 AM
Blades's Avatar
Last Online: 04-10-2008 12:03 PM
im not a big expert or anything but first just get use to moving in the air like doing small whips just get the feel of you bike cause if you not and you got your feet off or something you might be in trouble when you kick sideways.
Old 12-23-2007, 10:14 PM
Grieby54's Avatar
Last Online: 10-13-2009 06:32 PM
I be doin' them little whippertails and them one footers... I roll pretty hardcore.
Old 12-24-2007, 07:44 AM
Adhd Matt's Avatar
YZ250F For Sale
Last Online: 06-04-2008 06:13 AM
the brake tap has saved me many times, and it just feels good, lets you jsut stick them landings! and before i take anything off the bike im gettting my whips(for show) and scrubs(for speed) down, im already doing small whips ill sure get a pic when i get the cohonesto do one over our 100+footer, but right now im barely have enough to jump it
Similar Threads for: beginners tricks
Child trying tricks mxmama393 Mini Motorcycle Riders 64 03-26-2008 08:09 PM
What is the easyest trick to learn for beginners? Dakota R/T Misc Riding Types 34 07-19-2004 05:08 PM
Good jetting article for beginners zoohoot393 4-Stroke Motorcycles - General Discussion 13 03-18-2004 11:01 PM
125L for beginners Coachman 4-Stroke Motorcycles - Yamaha 21 09-24-2003 11:14 AM
what tricks? Yardpro393 2-Stroke Motorcycles - Kawasaki 4 05-18-2003 12:21 PM
