Old 10-10-2003, 06:53 PM
motorox's Avatar
Default Pay To Play
Only one week and I'm bummin...can't ride
OK gang, before I take it to the shop and take it in the @#$ let's make sure I did the best with your suggestions in my last post
The shift lever doesn't recoil back to the middle...so I have to tap it down each time to shift gears. It does go into to all the gears, just impossible to ride well
So I drained the oil and put in fresh...nothing
I drove around hoping it would work itself out as suggested...nuttin
Removed the clutch side cover and inspected. Not sure I did this part correctly. I removed the round cover (right side opposite of the shift lever) where the clutch attaches. seemed weird to look there because no view of where the spring attaches to shaft for shift lever. but saw nothing. EXCEPT so chips in the metal towards the center of the house. that can't be good. but probably unrelated?
any other thoughts
Old 10-10-2003, 08:20 PM
Blitz393's Avatar
Last Online: 07-23-2012 09:23 PM
Default Re: Pay To Play
is your clutch dead? shift fork? maybe some chipped teeth on the gears themselves?
Rob
Old 10-10-2003, 09:24 PM
motorox's Avatar
No it's mostly the shift mechanism. once you tap the lever back in position it shifts fine
Old 10-10-2003, 09:27 PM
Yardpro393's Avatar
you only took off the quick access clutch cover. you need to take off the whole side cover. on the bottom left corner you will see the shift shaft. there is a spring on it there. you will need to take off the clutch basket first though to get to it.
that's where to look.
Old 10-10-2003, 09:29 PM
motorox's Avatar
Figured i was off .....duh
Old 10-10-2003, 09:32 PM
motorox's Avatar
does that get complicated. If I take my time is is farily simple to remove that entire cover?
Old 10-10-2003, 09:41 PM
Yardpro393's Avatar
depends?
one 12mm bolt for the kickstarter, then pull off kickstarter, drain radiator remove hose to water pump, then about 10 or so 8mm bolts and the cover slides off.
you may not need to take the clutch off to get to the shift shaft, which is more than likely the culprit.
the ? is what's an afternoon and a little work worth to you.
there are alot of online sources to get an exploded diagram of the engine, so you can see what goes where.
Old 10-10-2003, 09:47 PM
MotoMan's Avatar
Last Online: 10-31-2018 03:40 PM
You can handle it, it really isn't that involved like yardpro said.
Just set aside a Sunday afternoon or something and take your time. You can handle it.
Old 10-10-2003, 09:52 PM
motorox's Avatar
Cool. sound like a good fall afternoon in the garage,,,smell of oil, some dirt bolts, gaskets,,,,hahhrrggghh!
thanks guys
Old 10-10-2003, 10:09 PM
Blitz393's Avatar
that's the best smell ever. well, it comes in second only to Maxima 927 premix
Rob
Similar Threads for: Pay To Play
Impeller play???? lbzrider 4-Stroke Dirt Bikes - Honda 2 04-16-2009 05:46 PM
Play in con rod lt 50 iash101 ATV/UTV - Suzuki 4 01-16-2009 08:39 PM
A game we can play racer_ryan247 General Discussion 2264 10-20-2008 12:51 AM
I need a play bike thumpers474 General Discussion 4 10-27-2004 08:04 PM
Does anyone else on here play MTX Mototrax on XBL? SXRacer22 General Discussion 0 08-04-2004 06:38 PM
